Old 03-11-2023, 04:33 PM   #1
chewychevy67
Factory door to fender line up
I took my 67 truck apart 15 years ago and have no other to look at and I'm wanting to line up my front end right now. But before I start I have 1 question. Anyone with a original truck can help me out here. The doors have a slight curve inwards at the front 2" of the skins. Do the fenders lineup smooth with the door at the very edge of the door or do the fenders stick out a bit to line up with the face of the door as if a straight edge was used across the door and fender?
chewychevy67 is offline   Reply With Quote
Old 03-11-2023, 07:08 PM   #2
cj847
cj847's Avatar
Re: Factory door to fender line up
I am no body man or truck expert, but I am going to say the fender should be slightly proud of the door. I know this is correct for the 60-66 models. The main reason is to keep the door from pinching the fender during the opening and closing action.
cj847 is offline   Reply With Quote
Old 03-11-2023, 07:36 PM   #3
70STOVEBOLT
70STOVEBOLT's Avatar
What do you mean by slightly proud?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 03-11-2023, 09:57 PM   #4
Rods
Rods's Avatar
The fender meets the the door as you say as if a straight edge is across the door and fender.
However, I always hang the doors first……and then go to the front starting at the core support then to fenders cowl etc…..
Just finished my 67 a few months back so I included some pics when I hung my doors and fenders
Hope this helps
Last pic something look familiar to you?
Az
Rods is offline   Reply With Quote
Old 03-11-2023, 10:22 PM   #5
Warrens69GMC
Warrens69GMC's Avatar
Pretty!!
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 03-12-2023, 10:13 AM   #6
cj847
cj847's Avatar
I don't have a number. But, as rods stated, hang the door first. Get the gap around the window and the back of the door looking good. Then set the fender with (as close as possible) the same gap as the back edge of the door to cab. Then add spacers as needed for the fender to clear the door + paint when opening and closing. Of course, the less the better for looks. It is only a few thousandths. I wonder if the "slight curve" at the front of the door is a design improvement from the 60-66 model?
Old 03-12-2023, 10:18 AM   #7
chewychevy67
Yep. The carburetor! Thanks for the info.
Old 03-12-2023, 08:32 PM   #8
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Does this help ?
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 03-12-2023, 10:14 PM   #9
HO455
Post Whore
HO455's Avatar
Due to the manufacturing process of the doors the slight curve you see at the edge of the doors is normal. Unlike later vehicles the doors are not a flat plane which then lines up with the flat plane of the fender and cab. You will need to get the best compromise fit of the door to the cab and then to the fender.
The other option is doing a lot of body work to reshape the edges of the doors and fenders which some folks do in the quest of a perfection in the door fitment. The factory was okay with the gaps being sort of constant and the edges being reasonably in line with each other.
RIP Bob Parks.
Old 03-13-2023, 11:06 AM   #10
72c20customcamper
72c20customcamper's Avatar
I didn’t try to “fix” the edge curl on the doors or fenders . Yes it’s nice to have laser straight sides . These trucks and even high end cars were not made that way . I just tried getting a nice even gab
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
72c20customcamper is online now   Reply With Quote
Old 03-13-2023, 07:03 PM   #11
chewychevy67
I thought they were curved so the moundings wouldn't jam up on the fenders. I assume they were stamped this way and if that's the case what's to fix. Just the way it was.
Old 03-15-2023, 12:03 AM   #12
cericd
cericd's Avatar
The term "Proud" = Taller Than (in this case, it means farther out)
Like "standing proud" is the same as "standing tall". In reference to the original question about fender and door fitment, it's a horizontal direction instead of vertical.
Chris
My 1970 SWB C/10 - https://67-72chevytrucks.com/vboard/...d.php?t=534872
cericd is offline   Reply With Quote
Old 03-15-2023, 09:47 PM   #13
70STOVEBOLT
Thanks for the explanation Chris
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
Old 03-17-2023, 11:46 AM   #14
cericd
cericd's Avatar
No problem. I remember being a little confused by that phrase the first time I heard it too but it makes perfect sense once you think about it.
Chris
