03-14-2023, 12:41 PM | #1 |
Optional factory horn?
I'm not sure if I'm reading this correctly. Was there an optional horn available?
03-14-2023, 01:11 PM | #2 |
Re: Optional factory horn?
Not sure about 73 - 80's but 81 - 87's Scottsdales and Silverados got a high note and a low note horns. Custom Deluxes just got the low note horn.
1972 GMC Jimmy 4x4 LS Swap 1985 Chevy K20 1994 GMC Yukon 2021 GMC 2500HD Duramax AT4 My "It's a Jimmy Thing" Build http://67-72chevytrucks.com/vboard/s...d.php?t=583528 Budget Build 1985 K20 http://67-72chevytrucks.com/vboard/s...d.php?t=801565 |
03-14-2023, 01:39 PM | #3 |
Interesting. If I understand correctly the high note horn is more for animals and the low note horn is for humans. My 78 has two horns which I guess are both low note horns. I'm going to try and replace one of them with a high note horn.
https://www.usa1industries.com/1973-...c-truck-horns/ |
03-14-2023, 02:25 PM | #4 |
If they are the factory horns, i believe that they should be stamped on them "Lo" or "Hi".
03-14-2023, 05:59 PM | #5 |
Another advantage of 2 or more horns of difference frequencies is you will also get a 3rd 'warble' note that is the interference frequency of the 2 horns. Not sure of the proper musical term. This 3rd note will have peaks with higher sound levels then either of the two base notes.
IIRC - Cadillac had 3 horns selected to create a special 'Cadillac' sound. |
03-15-2023, 10:34 PM | #6 |
My 84 GMC had both the high and low pitch horns already. Even though both of them now sound perfect after I tweaked the tuning screws on them (to break the years of road grime loose), I still had to add my auxiliary Hutchins horn:
https://blogger.googleusercontent.co...Image00013.jpg
I may be old, but I still enjoy the feeling of the earth rotating beneath my wheels... |
