Old 03-15-2023, 05:42 PM   #1
levib1
Oil pressure
1972 C20 originally L47 402, now 396 crate motor. Not many details on the engine.
Question in regards to oil pressure gauge. Attached is a picture.
During normal driving, oil P looks like in pic - at the 75% point on the gauge. Is this normal? Seems like it should be at about 50%? At least that's what other vehicles I have run at.
Are there different sending units? Calibration?
Probably a dumb question, but curious.
levib1 is offline   Reply With Quote
Old 03-15-2023, 06:47 PM   #2
RustyPile
RustyPile's Avatar
Re: Oil pressure
Connect a test gauge, one that reads actual pressure in lbs. A fresh big block will have pressure in the "upper normal" range.. After initial start-up my 454's cold oil pressure is almost 75 PSI, but after it reaches normal operating temperature, the oil pressure is around 50 PSI running and 35 - 40 at idle. Motor oil WT has a big effect on oil pressure.
RustyPile is offline   Reply With Quote
Old 03-15-2023, 07:41 PM   #3
cj847
cj847's Avatar
Re: Oil pressure
It looks normal to me. The gauge is usually 0-60 psi (some are 0-80, but you have to remove it to check). My old small block would almost peg my gauge at high rpm.
PS> the gauge is mechanical. It takes pressurized oil directly from the oiling system into the gauge.
cj847 is offline   Reply With Quote
Old 03-15-2023, 07:49 PM   #4
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: Oil pressure
The engine (L47) in my truck was rebuilt back in the '80s. It has always pegged the oil gauge (I'm guessing 60 psi), even to this day, when cold, and runs about like the OP's on the road. It's down to what I would say is 25 psi at hot idle, these days. Looks like normal, to me.
~Steven
Simi Valley, CA
Steeveedee is offline   Reply With Quote
Old 03-15-2023, 07:56 PM   #5
levib1
Re: Oil pressure
Thanks everyone for the replies.
Old 03-15-2023, 08:28 PM   #6
Sheepdip
Sheepdip's Avatar
Re: Oil pressure
Rusty Pile has your answer and good advice.
Sheepdip is offline   Reply With Quote
Old 03-16-2023, 12:22 PM   #7
KQQL IT
At the body shop.
KQQL IT's Avatar
Re: Oil pressure
Always gone with the theory.
If the lifters are quiet it's good to go.
However that's exactly where old blues 454 runs on the gauge
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
