Old 03-16-2023, 01:35 PM   #1
Cemack
Long to short bed driveshaft
Do you guys go to a one piece when shortening your truck?
Cemack is offline   Reply With Quote
Old 03-16-2023, 01:41 PM   #2
hevy_chevy67
hevy_chevy67's Avatar
Re: Long to short bed driveshaft
Yes, go with a one piece.
I put a one-piece on my shortened 69 C10.
1971 Chevrolet K10 - SWB, 5.3LS, 4L60e
1970 Chevrolet K5 Blazer - Project
1969 Chevrolet C10 - SWB, 350 Holley Sniper, 700r4
1969 GMC Suburban - 5.3 LS, 4L60e
hevy_chevy67 is offline   Reply With Quote
Old 03-16-2023, 02:27 PM   #3
tutone
tutone's Avatar
Yes. One piece is sufficient.
:My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=807535
1969 C10 swb/1968 Camaro 350/4spd
1955 210 2 dr sedan/1998 RCSB Z71/1977 Jeep CJ5
tutone is offline   Reply With Quote
Old 03-16-2023, 05:31 PM   #4
LS short box
One piece is good but check trailing arm cross member opening clearance if you are lowering the truck.
LS short box is offline   Reply With Quote
Old 03-16-2023, 07:24 PM   #5
Trucknut57
Trucknut57's Avatar
For those that have shortened their trucks, what length did your driveshaft end up being?
I shortened mine and took some measurements for the driveshaft and came up with 58". Does that sound close?
Somehow, the idiots survive despite their best efforts to kill themselves.
- dcozzi
Trucknut57 is offline   Reply With Quote
Old 03-16-2023, 09:43 PM   #6
Grumpy old man
Grumpy old man's Avatar
Close only counts with horseshoes and hand grenades , Most driveline shops will have a website with measuring directions , Verify with the shop you use that the measurement is correct before having it built . I had a new driveshaft built for my 67 factory shortbed V8 4 speed and it measured 59 1/2" center to center .Cost was about $300.00 with the yoke I provided and them using Spicer u joints
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 03-17-2023, 12:23 PM   #7
Accelo
Accelo's Avatar
I had a driveline that was hanging around here shortened.
Described at the driveline shop as a cut and weld. A re-balance and I was good.
If you are lowering your truck you will have to remove the bracket for the driveline bearing center hanger. I would remove it either way just to be safe.
Cheers
Accelo is offline   Reply With Quote
