![]() Join Date: Dec 2009
Steel bed to wood bed conversion
Did a search.
Looking for information on converting MY steel bed to a wood bed. It's a long fleet side. Can somebody please point me in the right direction. I want to remove my steel floor and install a wood bed I thought I saw something on you tube but cant find it Thank you |
![]() Join Date: May 2010
Re: Steel bed to wood bed conversion
Jim |
![]() Join Date: Jan 2007
You will need a different front bed panel (height is different), and the underneath cross sills. Aside from the wood and strips everything else should be the same.
Project "C10 Fever" (68 factory black 396 swb) Project “Faded Glory” (71 c10 med bronze original paint refresh) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
![]() Join Date: Dec 1999
The cross piece on the rear by the tailgate is different with a wood floor as well.
Smitty '71 Short Fleetside Spring Valley, Ca. |
SmokeyRoad Rod Shop has a kit that lays on top of the steel floor.
I am using their bedwood kit in my 70. But, mine was originally wood to begin with. |
I know of several vendors who can supply the parts for wood beds.
Has anybody done such a conversion? |
I had mine done when the rest of the truck was done. Steel to wood. I had picked up a long bed from a wrecking yard with new oak, kept the floor assembled standing on it’s side in the garage for 20+ yrs. Cut it down to a short bed and used it in my truck. Therefore had everything needed. Front panel, Lower supports, and the rear cross sill. Looks great. Good luck. Mar-K is a good choice for materials.
So what's different between the two front bed panels?
Some vendors for truck parts have posted video's on the differences and they state that while the front bed panels are different the steel floor panel can be used after a simple modification that removes some sheetmetal . Can anybody explain this. My floor is metal I want to use my existing sheetmetal in the conversion |
#9 | |
![]() ![]() Join Date: Apr 2022
The Twins: 1968 C10 SWB - Blue 327/5 Speed 1968 Camaro SS/RS - Blue 327/4speed C10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=833278 The "Others" 1933 Ford Pickup (Camaro in disguise) 2017 Camaro SS Life long Chevy guy |
Roto Reuter thats the name...
![]() Join Date: Feb 2010
Wood floor front bed panel on the left. Steel floor front bed panel on the right.
~ Dan ![]() My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
| Bookmarks |
