Old 03-21-2023, 08:05 PM   #1
burnem
WTB the middle console and seat for buddy buckets
I am Looking to purchase a complete middle seat with the storage box underneath for 67/68 Chevy/GMC buddy buckets seats. I actually don't need the cushions just the metal box and hinge, and a driver seat slide release lever handle.
burnem is offline   Reply With Quote
Old 03-21-2023, 09:00 PM   #2
Grumpy old man
Grumpy old man's Avatar
Re: WTB the middle console and seat for buddy buckets
If you can't find a used one check with Ricks .
https://ricksupholstery.com/
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 05-15-2023, 11:22 AM   #3
burnem
ttt
Old 07-15-2023, 11:38 PM   #4
burb71
Active Member
I have this set up...
Under seat storage box has rust on the inside but as you can see the bottom is clean so no rust through.
Backrest board with foam attached & angle iron bracket for mounting to the storage box hinge. Rusty but solid, bead blasting and paint will clean it up good. One bolt of the 4 is broken off inside one of the nuts, broken bolt is in upper left hand corner.
Seat cushion board no foam.
$225 plus shipping.
burb71 is offline   Reply With Quote
