Old 03-23-2023, 09:37 AM   #1
BanjoDude
To HEI or not to HEI - 69 C20 with Stock 307
Hi all,
I have a bone stock 307 in the C20 I just acquired. It purrs like a kitten as it is, and I'm trying to decide if I should convert to HEI or just throw another set of points and a condenser in the glove box and call it a day (I'm completely comfortable adjusting and replacing points). Those of you who have converted to HEI - do you have a suggestion as to which kind? I do not plan to ever build the engine for high performance - plan to keep it completely stock. I see that Rock Auto has the AC Delco conversions for around $175 and the knockoffs are much cheaper. Any thoughts would be appreciated!
Wes
Found Grandpa's old '69 Chevy C-20 - It'll never leave the family again.
"For just a little more, you can do it yourself!"
BanjoDude is offline   Reply With Quote
Old 03-23-2023, 09:46 AM   #2
yote1234
yote1234's Avatar
Re: To HEI or not to HEI - 69 C20 with Stock 307
look into petronix . you keep you dist but replace the points with electronics! no more points but completely stock. my 350 ran smooth with points but with electronics i noticed a difference. smooth smooth smooth.
1971 K5 CST Blazer
1965 C10 Short bed all original
1949 gmc 100
1968 Honda mini-trail z50a #377
1966 uh 1-D Huey
yote1234 is offline   Reply With Quote
Old 03-23-2023, 09:48 AM   #3
Yamariv
Yamariv's Avatar
Originally Posted by BanjoDude View Post
Hi all,
Wes
Only thing I can add is make sure to change out the points resistor power wire from the loom and replace with a nice big 10 gauge 12 volt wire to power the HEI. The resistor wire will cause issues as it only supplies 9volts (ish) for the points. I just redid this on my truck, job wasnt bad at all.
1971 Chev C10 - 250ci L6 w/3 speed on the floor
Upgrades: Power Steering
3 Core Radiator
7 Hole Gauge Cluster
Power Brakes (Incoming!!..)
1971 350 (Incoming!!..)
Yamariv is offline   Reply With Quote
Old 03-23-2023, 09:58 AM   #4
72SB
+1 on just using a Pertronix in stock Dizzy.
Ys you need to remove the resistance wire from + coil (just tape it back into harness) and run a stranded copper 10 gauge wire from IGN tap on fuse block to + coil
Pay attention to install 411 relative to shims included in kit. I find it easier to just pull dizzy and install Pertronix n bench.
72SB is offline   Reply With Quote
Old 03-23-2023, 10:05 AM   #5
Warrens69GMC
Warrens69GMC's Avatar
I owned my 69 GMC for 20 minutes before switching to HEI. I grabbed a low mile distributor and wires from u-pull-it and a 10 gauge power wire from the parts store. Ran the power from the fuse boxed (switched).
Worked like a charm.
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 03-23-2023, 10:23 AM   #6
BanjoDude
I tried to use Pertronix in an MG I owned a few years back and had a terrible time with reliability - they let me sit 3 times, and Pertronix support was rude and completely unhelpful in finding the root cause. I finally just sent the thing back and had to dispute the charge with my credit card company to get a refund. I'll not be giving them another dime based on that experience.
I'm interested in the HEI from the pick--pull. Pardon the ignorance, but can I pull a unit from a newer model and use it? Are all SBC dizzys essentially the same?
Old 03-23-2023, 10:43 AM   #7
Warrens69GMC
I pulled mine from a 305 Caprice 1979
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 03-23-2023, 10:52 AM   #8
jimijam00
Hei
jimijam00 is offline   Reply With Quote
Old 03-23-2023, 11:03 AM   #9
KQQL IT
At the body shop.
KQQL IT's Avatar
From 74 til 83-86 maybe they get some weirdo timing controls near there then mid 87 was efi
" That didnt make it any newer "
" Dont antique the equipment "
KQQL IT is offline   Reply With Quote
Old 03-23-2023, 11:33 AM   #10
72SB
OP, given most "new" aftermarket HEI dizzy are built with offshore components, pulling a GM (AC Delco) from a mid 70's car from junkyard would work. Kind of a crap roll with any pick & pull part but those dizzys were pretty stable with the 4 pin modules.
Typically the HEI has male post vs female so your plug wires would need changing or cut/install new ends for HEI cap
Pertronix like any company can have issues be it defective components or user errors. For me and many others they have worked fine. Correct installation is key, specifically in measuring gap in shaft and pickup to ring distance which is why various shims (washers) are included.
Old 03-23-2023, 11:36 AM   #11
palallin
Stick with the points: there is not enough difference to make the effort worth it. As soon as I can find another intake, I am changing back to points.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline   Reply With Quote
Old 03-23-2023, 11:51 AM   #12
54blackhornet
54blackhornet's Avatar
I dropped one of those cheap Chinese HEI units in my 307 few years ago. It’s been operating fine knock on wood ! Engine starts and runs much better than with the points.
71 C-20
07 Magnum RT AWD
54blackhornet is offline   Reply With Quote
Old 03-23-2023, 12:48 PM   #13
Southcity
Southcity's Avatar
I think you will get a good 50/50 mix of some folks saying to stay with points and others saying HEI on a post like this. It can potentially make the decision even harder. I used to wonder the same myself over the years having owned/built multiple different C10 pickups and 60-66 Suburbans. Sometimes, you just have to pull the trigger, try an HEI (or even Pertronix) and experience the change/difference for yourself, then decide. I personally have found HEI to be a great improvement every time.
66 GMC Suburban Custom
66 Chevy K10 Suburban
Southcity is offline   Reply With Quote
Old 03-23-2023, 01:17 PM   #14
OregonNed
OregonNed's Avatar
Same results for me - very happy!
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline   Reply With Quote
Old 03-23-2023, 02:27 PM   #15
jimijam00
Originally Posted by 72SB View Post
OP, given most "new" aftermarket HEI dizzy are built with offshore components.....
Pertronix
Isn't Pertronix made offshore?
Old 03-23-2023, 02:42 PM   #16
72SB
IDK, they have a 60,000 sq ft place in Irwindale, CA. they are part of the AAM group so I would suspect some of their stuff is manufactured off shore or the parts are and assembled here. Their headquarters are in San Dimas, CA
When I called for tech help it was San Dimas and the tech said my replacement module was being shipped from Irwindale, CA. A car I bought had the module, so I had no receipt, but they sold me one at a discount. PO. did not set the spacing up right, to tight, which caused it to rub on PU wheel. The car is running great as did the 327 I had in it with the Pertronix module before that motor finally died at 145k mi
Old 03-23-2023, 03:43 PM   #17
MARKDTN
Another vote for HEI. Good points (and condensers) are getting harder and harder to find.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 03-23-2023, 05:21 PM   #18
jimijam00
I just checked their website for ignition products.........not one mention of Made in the USA anywhere.
I've got a 117,000 sqft Amazon warehouse 10 miles from me, and it's filled with stuff from China. Nice American workers though.
Old 03-23-2023, 07:38 PM   #19
tim_mc
tim_mc's Avatar
I went with a new GM HEI 93440806 on my project (made in Taiwan). The coil went out a year or so later. I upgraded to a Davis Unified Ignition (DUI) 50KV coil and module. It made a huge difference.
1967 C20, 350 SBC w/Comp roller cam, 700R4 w/3.42 posi, PS, 4-wheel PDB, Old Air AC & GM Tilt column.
tim_mc is offline   Reply With Quote
Old 03-23-2023, 09:20 PM   #20
I'd leave the points. How many years have they run that truck now? Nothing wrong with points except people neglected to tune their vehicles up. Now that we have electronic ignition people run their spark plugs until they rust into the head
Old 03-23-2023, 09:50 PM   #21
67 twins
Location: Herculaneum MO (20 minutes south of St. Louis
Never a problem buy blue streak ignition components. Have always been the best and can be purchased at any auto parts store in the country.
67 C10 283 T5 swapped longbed fleetside = wife's daily driver(divorced)
67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck
67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD(Sold)
72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck(divorced)
73 El Camino SS 454 4 speed my first big block
Can you tell we are fans of longbed fleetsides & 67s
Chris
67 twins is offline   Reply With Quote
Old 03-23-2023, 10:03 PM   #22
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
Or until the resistance is high enough that the system punches a hole right through the rotor, seeking a better ground.
~Steven
Simi Valley, CA
Old 03-23-2023, 10:05 PM   #23
67 twins
I think all these people that say there truck runs better, smoother or starts easier with HEI are fooling themselves. They get a truck that's not running right & rather than just do a tune up they decide to upgrade. They put an HEI in and "It runs so much better now." Well of course it does, you did a tuneup when you installed the HEI. It would run just as well if you had just done a tuneup. I'm willing to bet none of them took out a well setup points ignition to install an HEI for a good comparison.
The only real advantage to an HEI is less maintenance. However as others have mentioned they can fail & leave you stranded.
Chris
Old 03-24-2023, 07:45 PM   #24
jocko
jocko's Avatar
If you'd prefer not having to do tune-up on occasion AND don't care if it doesn't look original, swap in a GM HEI. Very reliable. I'd carry a spare module in the glovebox, then you'd have no worries.
If you like doing tune-up work AND prefer the original appearance, keep the points. They work just fine, and you'd be one of an ever-shrinking segment of the population that even knows what points are, let along how to set them.
If you don't like doing tune-up work BUT want an original appearance, go Pertronix as mentioned above. Great option.
If you don't want ANY distributor, swap in an LS.
All of the above are good options, except the last one
Old 03-24-2023, 08:48 PM   #25
jimijam00
