Old 03-25-2023, 06:25 PM   #1
Joyridin
SWB Fleetside bed question
Somebody put a tonneau cover on my bed years ago. I guess back then, they weren't to caring about how it was installed. They put the snaps on the outside of the bed about 3" from the top of the bed.
Well, I removed them, welded up the holes, and filled it. My question is this: Are the sides of the bed flat, or do they have a very slight out outward radius to about the center of the wheel arch, then radius back in? If they are flat, I have a heck of a lot more sanding. If they are slightly arched outward, then I am probably done.
Joyridin is offline   Reply With Quote
Old 03-25-2023, 08:46 PM   #2
JDL
JDL's Avatar
Re: SWB Fleetside bed question
It's not flat it has some arch
72 Chevy short step side with 454 air and tilt.
72 nova project car
63 chevy II drag car
Agency Iowa
JDL is offline   Reply With Quote
Old 03-26-2023, 12:36 AM   #3
Casper42
Casper42's Avatar
for the life of me, I have no clue what you're attempting to explain. My thought, if you have a question, simply find a 67-72 Chevy/GMC in your area and take a look to give you the info you need.
'72 C10 Cheyenne SWB North Carolina truck for 50 years, 72k original miles, Medium/Hawaiian Blue, 3 owners - one for 40 years, garaged kept, original: sheetmetal, undercarriage, moldings, glass
New - engine rebuild at 65k in 2015, one repaint in 2010, new front bumper, houndstooth seat, carpet, 8 inch rally wheels on 275-60R-15, LED lighting. - Semper Paratus!
Casper42 is offline   Reply With Quote
Old 03-26-2023, 08:25 AM   #4
Joyridin
Thanks! That saved a lot of sanding time.
Old 03-26-2023, 08:27 AM   #5
Joyridin
That's a little hard this time of year sine they are probably all in storage. No worries. JDL understood without any issue.
Old 03-26-2023, 08:33 AM   #6
Grumpy old man
Grumpy old man's Avatar
There is only one resource you need as far as doing bodywork / paint on your truck .
https://www.youtube.com/watch?v=6_uadHnQEc8
Watch all the Stout customs videos . the guy is an excellant body man .
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 03-26-2023, 09:24 AM   #7
Joyridin
Those are nice videos! Thanks!
Old 03-27-2023, 09:16 AM   #8
I'm not sure what the arched comment refers to. Maybe he meant slanted above the arch. It is slightly slanted in all the same front to back. 'Back then" it was those who cared more than others either about looks or to protect the bed who had tonneau covers. That's what a tonneau cover is and that's the only way they were installed. It was many years later that the modern frame-type tonneaus came to be. GM offered snap on tonneau covers as an accessory. It was not uncommon to see expensive European sports cars, like Porches, to have snap-on tonneau covers installed. It was on open top cars where the concept of tonneau covers began, then carried over to customized pickups later
Old 03-27-2023, 10:21 AM   #9
Grumpy old man
Back in the 80's and 90's I built 100's of tonneau covers on truck beds and the last thing I said to every owner is "You understand I'm going to drill dozens of holes in your truck and pop rivit the snaps on ?" I even put a few on my own trucks , I'll probably put one of the new no drill ones on my 67 when it's time .
Old 04-03-2023, 11:12 PM   #10
Peanut74
If you really want to make sure the contours match use something like this. It's used by flooring and carpenter to go sound odd shapes.
1967 C10 "Snowball" (Currently in a thousand pieces down from a bazillion)
1989 Toyota DLX pickup "The Hulk"
Peanut74 is offline   Reply With Quote
Old 04-04-2023, 05:29 AM   #11
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
I've been using one of these for years, no holes in the bed and the price is right. Made In The USA! https://www.crafteccovers.com/1967-7...-Bed_p_14.html
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
