Old 03-25-2023, 09:46 PM   #1
Accelo
Accelo's Avatar
4x4 shift handle pivot bolts
I machined some 4x4 shift handle pivot bolts using existing bolts as patterns.
I have a 1970 205 transfer case adapter plate and it requires a 9/16" thread.
I believe the newer ones may require different threads.
I have 9/16", 1/2" and 7/16" bolts.
Price is $30 plus the ride.
I pictured the originals alone with the replacements.
I can add the zert fitting for $5 extra.
Accelo is offline   Reply With Quote
Old 03-25-2023, 09:56 PM   #2
Getter-Done
Getter-Done's Avatar
Re: 4x4 shift handle pivot bolts
Those look Great
You use Hex stock to start these?
Great job
The early bird gets the worm,
84 Chevy K-20
Old 03-26-2023, 03:06 AM   #3
Accelo
Accelo's Avatar
Yes, I did use hex stock to build them. Not a hill of beans different in material costs and saved me some work.
Old 03-26-2023, 09:19 AM   #4
cbeerman
Do you plan to make these on the regular or should I go figure out what I need now?
cbeerman is offline   Reply With Quote
Old 03-26-2023, 09:59 AM   #5
Thealien
Thealien's Avatar
Great job for a good price. Well done, sir.
Old 03-26-2023, 11:53 AM   #6
Accelo
Accelo's Avatar
I will be able to make them to order till I run out of stock.
Old 03-26-2023, 12:55 PM   #7
Johnl48
I'll take one for a 70
Old 03-26-2023, 02:05 PM   #8
Accelo
Accelo's Avatar
The 70 205 likely has the 9/16 NC thread. If you can confirm that it would be great.
That's the one I will send if you are unable to confirm.
PM me with and address and we can do paypal?
Edit.
I didn't know about the thread size change pointed out by Classic Bowties.
It does identify the one I have as a 1972. Always learning something.
Old 03-26-2023, 04:54 PM   #9
Johnl48
Pm sent
Old 03-26-2023, 05:31 PM   #10
Classic Bowties
Always on the hunt...
As an FYI for you and possibly all of your buyers, the OE 1970 trans to transfer case adapters were tapped for the 7/16"-14 NC threaded shift lever shoulder bolt, the 9/16"-12 NC threaded t/c lever pivot bolt was not used until the late 71 K model production year and became standard OE equipment all of the 72 K models. Given that these trucks have now been in service for fifty plus years and the possibility of broken parts being replaced, modified and or trans/transfer conversions being done throughout them years, it's always best to physically check your own adapter threads. Glwts, Mel
***For any return/past customers & friends***
Before sending of any funds, please wait for a confirmed total and instructions for
sending as our payment account info has been changed as of Jan. 2023. Thanks...
Classic Bowties is offline   Reply With Quote
Old 03-26-2023, 05:40 PM   #11
Johnl48
Thank you, I'll double check tomorrow. All I have around is a 1/2" bolt and it went in sloppy
Old 03-27-2023, 07:48 AM   #12
69cam
Does anyone know the bolt size for the advanced adapters TH350 to NP 205 adapter? Would like to buy one of these bolts when I know which size for sure to get. Thanks!
69cam is offline   Reply With Quote
Old 03-27-2023, 12:12 PM   #13
Accelo
Accelo's Avatar
The Advanced Adapter page is listed it this way:
This adapter was originally used on GM 4wd trucks 1971-79 equipped with a TH350 automatic transmission with the NP205 cast iron, part time transfer case.
One could assume from the year it's the later 9/16". I would call and confirm.
Old 03-27-2023, 12:47 PM   #14
69cam
I'll take a 9/16 with grease fitting. I was waiting on an email from advanced adapters, but went ahead and called. Great tech service! He looked up the drawings for it and confirmed 9/16-14. Please pm payment info. shipping to 62450.
Old 03-27-2023, 01:52 PM   #15
dave666693
dave666693's Avatar
where in WA are you?
67 C20/
68 C10 stepside/inline 250--current project
71 GMC 4x4
70 Blazer project-Zombie assault vehicle
67 4x4 Burb
dave666693 is offline   Reply With Quote
Old 03-28-2023, 01:48 AM   #16
Accelo
Accelo's Avatar
I am in Longview. 36miles North of Portland OR on I5.
Johnl48's bolt left in the mail today.
I will finish up the grease fitting bolt tomorrow. A Small Flat rate box is $10.50. A 5" cube box that weighed in at 7oz cost more to ship than the flat rate box. Go figure.
Any others can just figure shipping as a Small Flat rate box at $10.50.
Old 03-28-2023, 04:38 AM   #17
69cam
Payment sent. Thank you.
Old 03-28-2023, 09:55 AM   #18
CKfan
Nice machine work
CKfan is offline   Reply With Quote
Old 03-28-2023, 12:58 PM   #19
spudly
spudly's Avatar
I'll take a 9/16 with a zerk fitting if they're available. Thanks!
spudly is offline   Reply With Quote
Old 03-28-2023, 03:08 PM   #20
dave666693
dave666693's Avatar
I would like a 7/16 bolt. please send me your payment info. Thanks
67 C20/
71 GMC 4x4
67 4x4 Burb
Old 03-28-2023, 07:20 PM   #21
Terrysch
I will take a 9/16” one with zerk fitting for my 1972 GMC Jimmy 4x4.
Please confirm that you have one.
So I can pay you via your PayPal including the $10.50 for shipping to our 65721 zip code for Ozark, MO.
Thanks!!!
Terry
Terrysch is offline   Reply With Quote
Old 03-28-2023, 07:46 PM   #22
A1971Blazer
A1971Blazer's Avatar
Go to Pirateship.com....I ship small items in a padded envelope...it's usually around $4.50 $5.00 for a 8-10 oz package.
What grade of steel are you turning these from?
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 03-28-2023, 08:16 PM   #23
Accelo
Accelo's Avatar
Payment received and package sent. Thank you.
Old 03-28-2023, 08:28 PM   #24
Accelo
Accelo's Avatar
I added a zert to a couple bolts today.
Old 03-29-2023, 04:34 PM   #25
Johnl48
Got mine today, perfect fit. Thank you
