03-27-2023, 10:10 AM | #1 |
Question about original wheels and valve stems
Yippee, my hub caps are done - A long time coming. I have a 71 C10 with original 5-lug steel wheels. Happen to know what size those wheels are? Perhaps they're 15x6, not sure.
What color code are the wheels? I'm wondering about valve stems. What type and size of valve stems were installed in these? Is there a better option than original? Any leads appreciated. Thank you
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 03-27-2023 at 10:27 AM. |
03-27-2023, 11:42 AM | #2 |
Re: Question about original wheels and valve stems
I assume a regular rubber valve stem was used. A "upgrade" would be to use a steel, usually chromed, valve stem. Most tire stores carry them.
if you are a "has to be original look" guy, than use regular rubber valve stem. I have Crager's so of course use the metal ones. |
03-27-2023, 11:47 AM | #3 |
I do like the looks of the rubber valve stems. Happen to know what size?
This seems to be an original valve stem, assuming its not a GM replacement part. Looks like my wheels already have them, though mine aren't what I assume is brass.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
03-27-2023, 01:06 PM | #4 |
The brass one you have, like your pic, are better than rubber IMHO.
I don't know what the trucks came with as I am not a has to be original guy so if that's what you are asking, ideally someone who knows what factory installed can advise. |
03-27-2023, 03:16 PM | #5 |
This is my original spare (even the tire is an original). However, mine is a C20 which could have different from a C/10 due to GVW ratings.
I also prefer the brass.
Jim |
03-27-2023, 03:37 PM | #6 | |
I agree on the brass. Wow, original spare tire.
03-27-2023, 04:00 PM | #7 |
The parts book for 273476 reads “Demountable, W/2” cap, Tubeless Tire”. Not sure what is meant by 2” cap, but here are similar “2” valves. Seems 2” is the entire length, my existing stems (similar or same as post #5) extend 1.2" from the wheel.
Anyone know the wheel valve hole diameter? These are for 5/8”; I’m guessing the old wheels are the same. https://www.haltec.com/pc/2-quot-Rep...Stem-p3233.htm https://www.amazon.com/ACCRETION-TR5...995293079&th=1 https://www.ebay.com/itm/11123336727...RoCsDgQAvD_BwE
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 03-27-2023 at 04:09 PM. |
03-27-2023, 06:27 PM | #8 |
on your amazon link...the other model,TR501, is the 1 1/2" ones
https://www.amazon.com/ACCRETION-TR5...995293079&th=1 |
03-27-2023, 08:11 PM | #9 | |
https://www.ebay.com/itm/27367218466...BoCSxQQAvD_BwE
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 07-12-2023 at 10:19 PM. |
03-30-2023, 12:26 PM | #10 |
Great info on the valve stems. Wish I had thought to ask about this prior to having my tires mounted on my freshly powder coated steelies.
Regarding your color code question, this thread, https://67-72chevytrucks.com/vboard/...d.php?t=620516, has quite a bit of info on the stock wheel colors. Including the following quote from SS Tim, "GM 521 (Ditzler 2185) white, same color as the white trucks or two-tone parts were 70-72." I'm not sure which hubcaps your running, white, stainless, chrome over brass or the full wheel covers. If they're the white caps, I would make sure to macth the white on the wheels with the white on the caps. If it's one of the last three I listed, it doesn't matter as much. Especially if your truck doesn't have a white roof or other white accents. |
03-31-2023, 12:56 PM | #11 | |
06-03-2023, 07:45 PM | #12 |
So, can anyone that has a C/10 with original wheels and really low miles (or if they are the original owner) verify if the C/10's came with rubber or brass valve stems?
Hey Jim, I was looking at the pic of your original spare tire and noticed the unique shape of the valve stem cap. Would it happen to say DILL 627 around the raised area on the cap? |
06-03-2023, 08:01 PM | #13 |
I believe all 3/4 and one ton trucks came with metal valve stems . This is because they are run with higher pressure than the 1/2 ton tires .
06-03-2023, 09:03 PM | #14 | |
Is there something special about that? Like...are they valuable?
Jim |
06-04-2023, 12:16 AM | #15 |
They don't seem to be particularly valuable. NOS originals seem to sell for a bit more than the repops. Not sure how many manufacturers repop them but they're available from many classic car sources. Looks like Dill was an OEM supplier for valve stems and caps to at least GM and Ford. Seems Ford caps were grey. Looks like the 627 caps were used on the Vettes and Camaros up until a certain point.
Still wondering if the 1/2 ton trucks originally came with rubber valve stems. Last edited by cericd; 06-04-2023 at 12:21 AM. |
06-05-2023, 09:02 AM | #16 | |
https://67-72chevytrucks.com/vboard/...d.php?t=844846
06-05-2023, 10:58 AM | #17 |
I saw that one for sale, didn't think to look at the valve stem though so thanks for bringing it up. I agree that it looks like a rubber valve stem. I see that it's 6-lug but it looks like a disc brake wheel. Would that be from a 4-wheel drive? I was wondering if the 2wd 1/2 ton pickups had rubber stems.
06-06-2023, 09:35 AM | #18 |
My parts book mentions three valve stem related part numbers;
All, Blazer: 3171598 (Type F- 3/8" OD x 37/64" long) (these are the rubber caps) All, Blazer: 273476 Stem Assy, demountable w 2" cap tubeless tire All, Blazer: 9422212 Extension, valve stem (1 11/32" O.L.) (these are valve stem extensions) These are what is listed in my '71/72 parts catalog (P&A 31 M) Looking at the wheel pages, there is one wheel listed matching your criteria that is 5 lug, 15" diameter 15x6JJ wheel size, (3972722 part number) 1-piece welded, tubeless, 1/2" offset, G78x15 tires (orginally), 4 hubcap attach clips or projections, 4 spoke or hand holes
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
06-06-2023, 06:40 PM | #19 |
Thanks. I looked it up and found the same info in my 1946-1972 Parts Manual. I haven't gotten good at deciphering some of the info though. So does this mean that a 1970 1/2 ton pickup could have had either a 1-1/4" snap in type (rubber?) part number 274083 or a demountable w/2" (brass?) part number 273476 valve stem? So I see that the A.R. after 274083 in my image means As Required. Required by what? Higher tire pressure?
07-12-2023, 10:55 PM | #20 | |
The stems are stamped Schrader CAN, TR 416. This stem on Ebay appears to have the Schrader stamp as well. Edit: Nice summary by MJN, above. To add to that (c10), I believe the lug nuts are part # 516637, which are 13/16" hex with 1/2-20 threads.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 Last edited by 71CHEVYSHORTBED402; 07-13-2023 at 05:21 PM. |
10-24-2023, 10:30 AM | #21 |
I just remembered I had this on display in my basement, this is an original, never used, spare tire from a 1972 1/2 ton 4x4 Suburban. It’s a 15x6 wheel. It has a rubber stem.
72 3/4t Custom Deluxe 402/auto 66k Original paint 71 3/4t 4x4 Custom Deluxe 10k original miles Original paint 71 3/4t Cheyenne 402 70k original paint 72 3/4t 4x4 Custom deluxe 72 3/4t 4x4 Custom deluxe 91k original paint 72 Cheyenne/30 Dually 69 Camaro SS396 4-speed 13 GMC 2500HD Duramax I bought new 05 Jeep Wrangler "Willys Edition" 12k miles (I bought new) 85 3/4 ton 4x4 Scottsdale 33k miles original paint 86 1 ton 4x4 SRW Silverado 454 restored 80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint 95 GMC 1 ton dually 4x4 my dad bought new 95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles 2002 2500HD 4x4 regular cab 6.0L 67k miles 2002 2500HD 4x4 regular cab 8.1L 28k miles 2003 GMC 2500HD 4x4 regular cab Diesel 93k miles 67-72 Parts for sale |
10-24-2023, 11:03 AM | #22 |
Hey Joe, thanks for adding this info.
10-24-2023, 01:19 PM | #23 | |
Active Member
David |
10-24-2023, 02:12 PM | #24 |
My factory optional 16.5" x 8.25" KH wheels on my '70 Blazer came with the brass valve stems. I have the dry rotted never dismounted spare.
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion.. 1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... 2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
10-31-2023, 11:15 PM | #25 |
I wonder if rubber stems Vs brass or stainless stems was dependent on the hub cap? In other terms, painted caps take a rubber stem, chrome caps take a metal one. Just guessing.
