Tilt column hub spacing?
Is there supposed to be a Spacer between the Canceling Cam an Steering Wheel Hub on my Tilt Column?
As I’ve said on previous threads, I bought the column used, so I don’t know if something is missing or not. The space in between the Cancelling cam and hub required me to fab a bushing so that the horn contact ring would keep in contact with the Spring loaded button. Is there a plastic spacer plate/dust shield that is missing? Like I said, I don’t know, so any insights will help. Thanks in advance. |
| Bookmarks |
