Old 04-02-2023, 01:42 PM   #1
Extended Power
Extended Power's Avatar
New Schott wheels...gonna narrow the rear!
Got my new wheels picked up.
Took some measurements today with just the new rims, compared to the old wheels.
Until I get the tires mounted on the rims, I think the rear will have to be narrowed at least 2, or 2 1/2" off each side.
Don't want the tires sticking out past the fenders.
Lots of room inside with the wider fenderwells, and leaf/Cal Trac suspension.
"If it ain't broken, fix it 'till it is!"
Extended Power is offline   Reply With Quote
Old 04-02-2023, 01:45 PM   #2
Extended Power
Re: New Schott wheels...gonna narrow the rear!
New tires...
They fill the fenderwells really good.
Old 04-03-2023, 03:16 PM   #3
Jason Banks
Jason Banks's Avatar
Those wheels are amazing. I couldn't bring myself to spend that much money.
Instead of narrowing the 12bolt you might consider the switch to ford 9 inch.
https://www.vannattafabrication.com/...les-p534693564
This guy has the specs for different wheel offsets and lips figured out.
Jason Banks is offline   Reply With Quote
Old 04-03-2023, 04:34 PM   #4
LS short box
Another place I would check for a custom 9" is Quick Performance. They are in Iowa.
LS short box is offline   Reply With Quote
Old 04-03-2023, 04:45 PM   #5
LockDoc
The Older Generation
LockDoc's Avatar
https://www.quickperformance.com/
Nice people to work with. They built the 3.90 Posi for my '34 Ford Coupe. They are about 80 miles from me.
LockDoc
Leon
Old 04-04-2023, 07:40 AM   #6
Joyridin
If you don't mind switching rear ends, look at an 8.8" from a Ford Explorer. It is 59.5" wms to wms. If that is still too wide, then you can narrow just the one side and make both sides the same length which gives you 56.5". They are all posi with either 3.08 or 3.73 ratio and all are disk brake except some earlier models. They also have a 3.25" axle housing diameter, so it is easy to weld on mounts.
Joyridin is offline   Reply With Quote
Old 04-04-2023, 10:34 AM   #7
Extended Power
LockDoc
At this point, the price was pretty heavy, especially after having to drop an new transmission into my Ford, and deal with an insane price for having the wider fender wells, and tailgate painted in January.
I have considered the c-clip eliminators, and also just having the Ford end caps welded on...but I’m not done with the rear end yet, and want to go with big brakes as well.....just can’t do it all right now.
Same thing applies to the wheels. I did the 3” dropped tubular A-arms, lowered the rear, disc brake/5 bolt conversion, Moser axles, Cal-Tracs, Tru-Trac, and gear set, a couple years ago, but no way could I afford the big disc brakes, or wheels, all at once.
I went for what I thought was the nicest 5 bolt aluminum wheels, that would get the truck on the road again, as cheap as possible. (Without just sticking used stuff on)
I have used Jason before...he is who I finally got my one piece window kit from, as Brothers was going on a year, come April for being backordered.
I tried to use Jason for the wheels initially, but the communication wasn’t exactly clear, and I didn’t want to spend all that money, just to open the boxes and say, “That’s not what I ordered”.
I dealt with Schott direct.
Clear, precise instructions, and answers, as well as some good advice. (Go with the 12” wide, instead of the 14”, even though I am narrowing the rear end.)
Old 04-05-2023, 03:50 AM   #8
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
I don't get it, why not simply order a deeper backspacing? I just ordered a set of Weld Draglite's with 7-1/2" backspacing to keep the 16" meats flush...?
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 04-05-2023, 04:03 AM   #9
Richard
Having a larger exposed lip in the front of wheel is a preference for some. Maybe that style wheel are not available in custom offsets? Everybody has a "look" that they prefer.
Richard
Old 04-05-2023, 03:56 PM   #10
72c20customcamper
72c20customcamper's Avatar
LockDoc
They are excellent customer service top notch and the rear is also. I had mine shortened 3/4 of an inch each tube to fit wider tires in my Chevelle . Was an easy swap
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 04-05-2023, 05:04 PM   #11
LS short box
Again maybe not for you but I've been running a 1996? Explorer 8.8 in my 98 Wrangler with a LS6/4L60E swap for over 14 years and zero problems. The 8.8 has 31 spline axles, Ford posi and 12" disc brakes with the e-brake built into the caliper.
I haven't had an issue but the pinion is offset not centered.
