04-03-2023, 05:47 PM | #1 |
Drivers door seal help!!!
Ok, I have been trying to install my door seals. The passenger side went on and after letting it set opens and closes fine. The drivers side has been the total opposite. No matter what I do I can't get the door to close all the way. If I close the door with no seal it shuts fine and is even with the cab. I put the seal on and it will not close all the way. I have tried both a Civic doorseal and new seal. What am I doing wrong?
-------------------------------------------------------- 1967 C10 "Snowball" (Currently in a thousand pieces down from a bazillion) 1989 Toyota DLX pickup "The Hulk" |
04-03-2023, 06:24 PM | #2 |
Post Whore
Re: Drivers door seal help!!!
Try putting an even layer of grease on the door or the seal (Depending on your paint color Pam will work) then shut the door. Then inspect the grease transfer. You may find that an area shows a wider contact band than the rest. If so the door needs to be shifted away from that area. This may cause your gaps to become less than perfect (Like they were from the factory. ).
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
04-03-2023, 07:11 PM | #3 |
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
04-03-2023, 10:14 PM | #4 |
Try loosening the inner door hinge bolts a little. Sounds like something up front is binding.
04-03-2023, 10:57 PM | #5 |
I swear this truck is possessed!! I went back pulled the seal off and reset the door. Gaps were good and it closed nice. Test fit the seal and the door closes a little harder but acceptable. So I start to glue sections of the seal on and suddenly the door won't close again!!
Before I went and got a can of gas and match I thought I would take a break for the night. Hopefully it's just a small adjustment and everything will work out. I'll go through the video again and everyone's suggestions again. Thanks guys
04-12-2023, 03:07 PM | #6 | |
04-13-2023, 11:58 AM | #7 |
Well it looks like I finally got it to an acceptable level. I did a combination of beating the snot out of the lip, as in the video, and moving the striker plate out about a 1/16". Now I need to put the sill plate on and hopefully nothing changes.
