Old 04-04-2023, 03:48 PM   #1
StevenG
66 C20 Dash light dimmer
The dash lights come on when you turn the key to on with out the headlight switch pulled out. Is this normal?
When you turn the headlight switch it only dims the taillights. That’s not right.
Any ideas?
StevenG is offline   Reply With Quote
Old 04-04-2023, 06:27 PM   #2
ray_mcavoy
Re: 66 C20 Dash light dimmer
Yeah, that's definitely not right.
Dash lights should come on when you pull out the headlight switch (even without the key on). But turning the key on (with the headlight switch off) should not cause the dash lights to come on. And rotating the knob should vary the brightness of the dash lights ... not the tail lights.
Sounds like there may be some wires crossed up on the headlight switch connector and/or elsewhere in the wiring harness. Can you see any signs of splices or other changes / modifications to the wiring?
ray_mcavoy is offline   Reply With Quote
Old 04-04-2023, 08:36 PM   #3
PGSigns
PGSigns's Avatar
You may have a ground loop going on. Ad some grounds to the bed, rear light buckets. hood and marker lights. See if that helps the dim lights. Then look at the back of the dash for added wires that may be screwing up the lighting circuit. I have seen some creative wiring over the years that made all kinds of things go on.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
