Cab B-Pillar Replacement
Does anyone make a replacement B pillar for a 67-72 C10? I found a complete rear cab replacement panel, but it's pretty pricey and I really only need the b pillar from the door handle down to about the lower body line. It looks like this cab may have been hit and someone used a slide hammer to pull it back out.
Re: Cab B-Pillar Replacement
don't know if any are made, but I would take hammer and dolly work over rust anytime.?..
Is there access to the back of the panel. I don't own a pick up so I have k ow ide ![]()
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
[quote=jaros44sr;9194191]don't know if any are made, but I would take hammer and dolly work over rust anytime.?..
Is there access to the back of the panel. I don't own a pick up so I have k ow ide ![]() I’m with you on the hammer and dolly work, but whoever did this drilled holes to attach the slide hammer. So it looks like Swiss cheese. There is access to the back, but it would take forever to weld up all the holes. It would be quicker and probably look better if I could put on a patch. |
All about them K’s
![]() Join Date: Jun 2014
Mine has damage in the same area, some one in the last 50 years munched the bed and cab together pretty good. I bought a good used cab cut from another truck that I’m going to use to replace the damage on mine. I hammered and dollied it out and it decent but the big problem is the metal is pretty thin from all the damage and repairs. Thin enough that there are many small pin holes in the metal.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
First choice: B pillar from donor truck...
Second choice: Patch panel. Install and then weld up remaining holes... Third choice: Hammer and dolly to reshape, then weld up each hole... |
![]() Join Date: Dec 2013
I've never seen a repop panel for the area your dealing with , your option is to start with a hammer and dolly to get it as right as possible weld up the holes and prep it for a base coat of fiberglass short hair filler and work it out from there . or buy a used part to replace the damaged area , What is the condition of the rocker ? The cab supports ? do you have all the tools to do the repair yourself ? , Using a repair panel from another truck would be the best way to fix it . if the cab has all the other usual rust maybe it's time to consider a cab replacement ?
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
#8 | ||
The cab is largely rust-free. The cab has had the rockers, most of the floors, and one cab corner replaced. The cab corner on this side is actually solid with only one hole that is small enough I think I can weld it up. The cab is actually the major reason I bought the truck, though I didn't realize at the time replace that B pillar would be a problem. Sounds like I need to keep looking for a donor. Thanks, again! |
#9 | |
Unfortunately, it’s the section from the lower body line up to about the door handle height.
That's the section I was looking at , How is the door lining up ? It looks like the gap doesn't match the door ? Maybe pushed back from the damaged section ? I'd try to align up that door and see how the gaps are all around before deciding on a fix .
![]() Just remember it's only metal , It can be hammered , streched, smoothed , cut and welded , and beaten into submission until your happy with it !
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop Last edited by Grumpy old man; 04-08-2023 at 10:10 PM. |
#12 | |
#13 |
![]() Join Date: Dec 2009
When I need a piece like that I normal reach out to this Member.
He has a FB page Link: https://www.facebook.com/truckinkrazy/ Here is his member's name here on the forum. t korinek He stays busy and sometimes there is a delay. But He always Follows Thru. Here is his last thread that would pertain to your request. Link: http://67-72chevytrucks.com/vboard/s...d.php?t=784390 Last post was January on page 3.
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
#14 |
The number of holes are concentrated in lower half of that area.. Install a patch panel and only a few holes remain above the patched area.. Per my second suggestion, most of the holes and stretched metal will be removed. My metal working skills are very limited.. Not saying others couldn't, but I probably wouldn't attempt a complete pillar replacement. But I wouldn't have a bit of trouble welding up all those holes and/or installing a patch panel.
#15 |
![]() Join Date: Dec 1999
Post #37 here in the parts board https://67-72chevytrucks.com/vboard/...=842608&page=2
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
#16 | |
All about them K’s
#17 |
What's the inside look like at the bottom, can you save it
#18 |
Post Whore
![]() Join Date: Feb 2016
You might reach out to member MP&C about whether it would be better to replace it or hammer and dolly. He's a very skilled metal worker. As shown here
http://67-72chevytrucks.com/vboard/s...d.php?t=564201 Personally I think I would weld the holes and hammer and dolly it.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#19 |
I'd hammer/dolly that and weld the holes. I only know of the complete back panel being made more recently. Until then there was nothing.
#20 | |
![]() A Copper backing Spoon (Or something Copper) Helps. Link for Example: https://www.amazon.com/Strong-Hand-T...90&sr=8-7&th=1
#21 |
Was just trying to provide an option that the OP preferred. We all have our preferences in the way we like to do things.
