Old 04-07-2023, 06:16 PM   #1
howzzzit
howzzzit's Avatar
New fuel system startup
New gas tank, fuel lines, and mechanical pump. Is there a way to prime the fuel system to prevent excessive cranking or just prime the carb and go for it?
72 C10 350
howzzzit is offline   Reply With Quote
Old 04-07-2023, 07:30 PM   #2
truckster
truckster's Avatar
Re: New fuel system startup
Drizzle some fuel down the primaries and crank it up.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 04-07-2023, 11:25 PM   #3
RichardJ
If you have the earlier truck without a evap system that uses a vented gas gap, you can use air pressure to push gas from the tank through the hoses, through the fuel pump and into the carb. Wrap a rag around your air nozzle and hold it into the tank filler neck. Give it a couple of quick shots of air and hold the rag tight.
Don't go crazy. You'll hear the tank "oil canning". Give it a couple of shots and check for accelerator shots in the carb.
Another method.
Most pre- smog carbs vent the fuel bowls into the neck of the carb. On a non-smog Edelbrock (without the side tube for the charcoal cannister) there are two squarish holes on top that you can pour fuel into the float chambers. Use a really small tipped funnel or an old hand oiler will work. A couple of tablespoons is all.
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 04-08-2023, 12:44 AM   #4
howzzzit
howzzzit's Avatar
It's a 72 C10 with the eec setup. Running a quadrajet. Ideas?
Old 04-08-2023, 08:44 AM   #5
ghackett1
68 C10 Longbed
ghackett1's Avatar
What he said.
ghackett1 is offline   Reply With Quote
Old 04-08-2023, 09:06 AM   #6
mrein3
mrein3's Avatar
Originally Posted by ghackett1 View Post
What he said.
Ditto. This is all I ever do when staring one up that has been sitting a while.
I just pour whatever gas I have laying around down the carb. The engine coughing and spitting on that gas is usually enough to get things primed. And yes, this is WAY better than cranking on the starter.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 04-08-2023, 12:01 PM   #7
HO455
Post Whore
HO455's Avatar
Fuel into the vent shown by arrow. A full bowl will idle the engine for about a minute depending on cubic inches and other things .
RIP Bob Parks.
Old 04-08-2023, 02:46 PM   #8
wrangler94
I also have a boat, so I had this tool handy, but I used the vacuum pump/tank deal used for oil changes (it's like a pump sprayer in reverse basically) and used that to the fuel hose going to the fuel pump to first pump all the bad gas out, then hooked it up near the carb, etc.. to prime everything so I wasn't doing a bunch of dry cranking. I also dumped chainsaw gas in the carb so it would have a little bit of oil to it to lube stuff. Mine had been sitting for years though, not sure about yours.
wrangler94 is offline   Reply With Quote
Old 04-08-2023, 03:13 PM   #9
Getter-Done
Getter-Done's Avatar
Yes this
I used an old vacuum advance and dissected it.
It makes a great funnel for filling the carburetor.
The early bird gets the worm,
84 Chevy K-20
Old 04-08-2023, 03:29 PM   #10
Grumpy old man
Grumpy old man's Avatar
.97 cent Plastic Squeeze Dispense Bottle at Walmart .
https://www.walmart.com/ip/Mainstays...from=topicPage
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
