Old 04-08-2023, 01:53 PM   #1
R.O.B.
Lower control arm, what years do they fit?
Hey, I've got a set of lower control arm from a 71 C10 that I want to sell. Can you guys tell me what years they will fit so I can make a good listing?
R.O.B. is offline   Reply With Quote
Old 04-08-2023, 11:45 PM   #2
R.O.B.
Re: Lower control arm, what years do they fit?
I assume 67-72 c10's, but anything else?
Old 04-09-2023, 12:11 AM   #3
Getter-Done
Getter-Done's Avatar
If you search to buy those you can sometimes find a good answer.
When I sell swap meet parts I use the Chain stores websites.
I also use Aftermarket stores and so on.
For your part Summit has an application chart.
Which can cause some confusion If you are not exactly sure of the part in hand.
Here is a link I hope this helps you.
Link: https://www.summitracing.com/parts/C...L/applications
The early bird gets the worm,
84 Chevy K-20
Old 04-09-2023, 12:33 AM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
71 lower control arms have a balljoint that will fit 1971 and 1972 trucks.
But 63-87 lower balljoints will press into those same control arms.
3/4 to trucks of those year have a different control arm due to their larger balljoint diameter.
Keith
Convert to disc brakes.
Old 04-09-2023, 07:42 AM   #5
R.O.B.
Thanks guys
