Old 04-08-2023, 07:04 PM   #1
GSP7
GSP7's Avatar
electric choke wire
Gonna convert to electric choke from manifold heat choke
On a factory elec choke truck where is the factory choke wire run from?
Yeah yeah , I know any "ignition on" source. See sentence above
'81 K20 Silverado , '99 Dodge Cummins 4x4, '05 Dodge Cummins 4x4,
Pinstriping-Lettering-Specialty Painting
GSP7 is offline   Reply With Quote
Old 04-08-2023, 08:19 PM   #2
hatzie
Moderator
hatzie's Avatar
Re: electric choke wire
They typically run through the oil pressure switch from an Ignition source.
Download the 1985 or newer wiring diagrams.
The heat stove choke coil on the intake is darn reliable. Why are you changing it?
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 04-08-2023, 10:14 PM   #3
GSP7
GSP7's Avatar
My '81 k20 has a 1970 Hi perf built motor in it. I moved to a Free state, no more smog check. My heat choke hasnt worked in years. Edelbrock Performer RPM intake.
Im Rebuilding my 800CFM Quadrajet with proper jetting and mods(from Cliff) to match engine build (cam headers etc). Redoing the distributor too
Old 04-09-2023, 08:19 PM   #4
hatzie
Moderator
hatzie's Avatar
Intake change makes sense.
Old 04-11-2023, 11:07 AM   #5
406 Q-ship
406 Q-ship's Avatar
Actually the Edelbrock RPM intake has the provision for the divorce choke coil and Edelbrock sells the coil and the extended rod for the RPM intake. If you use the 800 Q-jet from Cliff it will probably use an Electric Choke anyway. I have used the power feed for the wipers is a great source for an electric choke, just don't ever use the ignition hot wire to the coil (you'd be surprised hw many times I find a "professional" do just that). Hope this helps.
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride!
Where patience fails, force prevails
Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle."
406 Q-ship is offline   Reply With Quote
Old 04-12-2023, 03:44 AM   #6
Just call me Sean
Just call me Sean's Avatar
The power feed from the wipers is hot in accessory so that isn't a good choice.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
