Old 04-09-2023, 10:46 AM   #1
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
Wheel Stud Knurl Diameter? 72 C/10
I need to replace the studs in my 72 C/10 rear axles with longer ones. Does anybody know what the factory knurl diameter is on the 1/2 x 20 studs? Thanks...
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 04-09-2023, 11:47 AM   #2
kwmech
Re: Wheel Stud Knurl Diameter? 72 C/10
Rear stud (610- 138) is a .535 knurl with a 1-17/32 length. Nothing jumping out at me for a longer length.
front number (610-159) comes in at a .620 knurl with a length of 1-5/8''. With that one I don't see anything longer that will work without a significant increase in knurl diameter. but those are the factory part numbers
My reference is an old Dorman book (about 25 years old) when they used to actually put specs in print and was accurate
Old 04-09-2023, 01:01 PM   #3
Ironangel
Ironangel's Avatar
Thank you KW! I'm looking at Moroso 1/2 x 20 x 3" studs at Speedway, they come in a variety of knurl diameters, .594" .615" & .685" ... I'll pull an axle and press one out to verify... I just bought a set of Weld Wheels "Draglite's" that require 2-1/2" studs to meet NHRA rules. Thanks again!
"Two Seventy Two's"
02 3/4 ton Express
Old 04-09-2023, 04:34 PM   #4
ESC
Junior Member
Curious if you come up with anything. I’m looking for 3” .535 knurl for my rears as well
ESC is offline   Reply With Quote
Old 04-09-2023, 05:52 PM   #5
72SB
looks like long aftermarket ARP, etc studs don't come in a .535 knurl....seems the long stuff is for aftermarket axles...or drill out current axles for larger knurl sizes available in longer lengths
72SB is offline   Reply With Quote
Old 04-09-2023, 09:53 PM   #6
Ironangel
Ironangel's Avatar
I measured mine at .524" knurl, 1.47" length. The hole only measured .504" So, unless I can find something close to .524 I'll drill the axles... I wound up buying the Moroso 46185 wheel studs, 1/2x20 .594" knurl, 3" long and a 37/64 drill... Those Weld Wheels are an 1-7/16" thick through the holes! 15 x 12 Draglites w/7.5" backspace.
"Two Seventy Two's"
02 3/4 ton Express
