04-12-2023, 12:23 PM | #1 |
Brake upgrade for 15" wheels
I know there are big brake kits out there for running bigger wheels but is there anything out there for guys running 15" wheels other than just good pads?
Posted via Mobile Device |
04-12-2023, 03:37 PM | #2 |
Re: Brake upgrade for 15" wheels
I'm signed on ...
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
04-12-2023, 04:33 PM | #3 |
Following as well
1970 C10 to K20 conversion 1974 GMC Jimmy 1968 50th Anniversary Short Bed 1968 Chevelle 1964 Comet Caliente 1990 W250 Cummins |
04-12-2023, 05:58 PM | #4 |
I just have stock front disc but if you look at various aftermarket brands like Wilwood, Baer, etc,. they list "min" size wheel for their various kits,
I would think there is a multi-piston caliper made for 15" rims. More aggressive pads than stock and slotted and/or drilled rotors. The more aggressive the pad the more dust and rotor wear. Always a tradeoff |
04-12-2023, 06:20 PM | #5 |
I have manual disc brakes from a 1971 C10 on my 1969 C10 with 15 inch truck rally wheels, and it stops great.
04-12-2023, 09:24 PM | #6 |
I have power drums on my 68 3/4 ton, big block and it stops just fine
04-12-2023, 09:53 PM | #7 |
I've not seen discs bigger than 12" for 15" wheels(4 nub). You can get two-piston Wilwoods to clamp those down if you want.
04-12-2023, 10:28 PM | #8 |
I thought after 70 our trucks were disc?
04-12-2023, 10:33 PM | #9 |
04-12-2023, 10:49 PM | #10 |
The stock discs work really well if in good shape. Get some new rotors and a set of street compound pads from someone like Hawk.
04-12-2023, 11:06 PM | #11 |
Hydroboost will more than double amount of pressure to the calipers/wheel cylinders.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
04-13-2023, 10:50 AM | #12 | |
I haven't had any issues with my brakes but I want to add more power and potentially autocross so any upgrade I can get. |
04-13-2023, 01:48 PM | #13 |
Post Whore
Wilwood D52 calipers are very good and should work with your spindles.
https://www.wilwood.com/Search/PartNoSearch?q=D52 http://67-72chevytrucks.com/vboard/s...d.php?t=400209 Here is a thread with sciency stuff in charts that shows how D52's compare to other popular calipers. A lot of information to digest but worth the read. https://www.pro-touring.com/threads/...clamping+force You may want to look into converting to later model spindles that will allow you to run a thicker 1.25 rotor. http://67-72chevytrucks.com/vboard/s...d.php?t=317654 Have you read this thread? An even longer read but worth it if you desire to go out and kill kones! http://67-72chevytrucks.com/vboard/s...d.php?t=419251
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
04-13-2023, 01:52 PM | #14 |
Don't overlook the soft lines and the quality (age) of the brake fluid.
When I rebuilt my 72 Blazer I went with stock components, but everything is new. It stops really well.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
04-13-2023, 04:15 PM | #15 |
My 72 when I got it last year with 117k mi (disc/drum on 15's) was manual brake and had the original brakes. Needless to say they were worn to almost the metal under pads/shoes and the soft lines were very clogged.
I bought all new stock calipers, pads, shoes, drums, bearings, seals, soft lines from rock auto and the power booster/MC from CPP. It stops on a dime now. Very happy. If you are building a AutoX ride with 15" rims than a dual piston caliper, IIRC the Wilwood D52, slotted rotors and aggressive Hawk or EBC pads that would likely be better than stock. What really helps is replace soft lines with SS braided. Really forms up the brake pedal |
04-13-2023, 08:13 PM | #16 |
All ya need is hydra boost, it will put you in the windshield w/ 33s
16814310804127946505066559916248 by [url=https://www.flickr.com/photos/198023675@N07
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
04-13-2023, 09:54 PM | #17 |
Good deal
04-13-2023, 10:26 PM | #18 | |
Who Changed This?
04-13-2023, 11:14 PM | #19 | |
04-14-2023, 01:37 PM | #20 |
[quote=jaros44sr;9196205]All ya need is hydra boost, it will put you in the windshield w/ 33s
16814310804127946505066559916248 by [url=https://www.flickr.com/photos/198023675@N07[/quote] What all is needed to make this conversion? My LS I'm installing has the Hydroboost setup, but I'm not sure if it's beneficial for me to add it, or just plug the line in the PS pump.
1971 C10 - Hugger Orange/White My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=780197 LS Swap Thread: https://67-72chevytrucks.com/vboard/...d.php?t=811460 |
04-15-2023, 12:55 PM | #21 |
Post Whore
They do provide more braking power just be sure to get the correct size pistons. The D52's come in two different piston configurations.
04-16-2023, 01:45 AM | #22 |
My main objective on a driver vehicle with some moderate to extreme use is to have replacement maintenance parts readily available local in a short time. Which is why I choose to use all OEM components in my drivetrain and just increase the pressure with the modern hydroboost. Drilled and slotted rotors of the same size actually have less initial braking power than solid rotors due to less surface area, they only decrease brake fade. As far as calipers, if the stopping power is there, I do not care how many pistons are in them.
