Old 04-16-2023, 03:42 PM   #1
PuzzleTruck
Junior Member
PuzzleTruck's Avatar
Rear Diff I.D.
Can someone please tell me what differential I have? I believe it's from a '79 Blazer 4x4. It appears to be open, by the way it can move one wheel without the other, and what looks like a bar across the middle. Gears are 41/11 (3.73).
What is the strange little device inside? It's some kind of moving weight, like you'd find in a mechanical distributor advance. I've never seen anything like it, and web search hasn't turned anything up. I'm thinking of changing to a limited slip, due to the wear marks on the carrier from bad adjustment, and some evidence of corrosion on the teeth. If this is no big deal, can I reset the pinion and lash and continue to use it safely?
Thanks!
Toby
'59 Stepside w/ '55 front clip, on '79 Blazer 4x4
with '02 Vortec 6.0 and 4L60E
'66 Corvair Mid-engine EFI 350
My truck build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=832276
PuzzleTruck is offline   Reply With Quote
Old 04-16-2023, 03:48 PM   #2
Warrens69GMC
Warrens69GMC's Avatar
Re: Rear Diff I.D.
12 bolt with a Torsen gov-lock
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 04-16-2023, 03:56 PM   #3
PuzzleTruck
Junior Member
Re: Rear Diff I.D.
A friend just sent me a link to Eaton Gov Lock. Looks like that's what this is! Still the question, is it suitable for continued use with proper adjustment?
Toby
Old 04-16-2023, 03:58 PM   #4
PuzzleTruck
Junior Member
Re: Rear Diff I.D.
Thanks for the quick reply, Warrens69GMC. Are the Torsen and Eaton the same part?
Toby
Old 04-16-2023, 03:59 PM   #5
Warrens69GMC
Re: Rear Diff I.D.
You might want a rear end expert to make that decision. When I see wear on the carrier, I usually look for another rear or have mine revuilt.
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 04-16-2023, 06:46 PM   #6
mongocanfly
mongocanfly's Avatar
Re: Rear Diff I.D.
That looks bad.. pinion been rubbing the carrier..
On the govlock it can be several things that keep it from working.. worn clutch discs and broken teeth on the engagement gears are what I've seen
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 04-16-2023, 07:59 PM   #7
kwmech
Re: Rear Diff I.D.
The gov-locs at this point are old tech. Every one of those I rebuild I talk the customer into a Tru-trac and never look back. Everybody has been happy with the change over.
