04-17-2023, 01:18 AM | #1 |
NP205 Skid Plate
Anybody ever see one of these on a 4wd truck? This is on my 76 K20. Never seen one before. Was this a factory option? The fuel tanks also had skid plates, but I've seen those before, just never a skid plate over an Np205.3
04-17-2023, 02:21 AM | #2 |
Re: NP205 Skid Plate
I used to see them all the time when square body trucks were more prevalent. I may have a few of the pieces kicking around in "the pile"
04-18-2023, 07:41 PM | #3 |
1972 K5 Blazer had a skid plate from the factory for a np205
04-18-2023, 09:16 PM | #4 |
I'm thinking that GM(though it might have been Ford) had a cantilevered skid-plate over the aluminum transfer cases of the 1980's; not the double-crossmember deal that you're showing here.
If I was adding a really solid skid-plate to a truck, I'd probably do it like you show. Find another identical crossmember in the junkyard, and bridge between the two with a scrap of 3/16" steel plate. I'm not really answering your question as to whether it's factory or not. But I could easily see it being an owner-contrived setup. Look at the steel plate, and see if it shows any evidence of crude cutting; oxyacetylene torch spatter, angle-grinder grooving, etc. If you see anything other than perfectly-clean cut lines, it might indicate it's pieced together after-fact.
1987 C6P V20 truck, 2010 LMG 5.3, AFM delete, 2010 Camaro exhaust manifolds, 1997 nv4500, 1991 np241c, hydroboost, 2005 14bff axle & driveshaft, drop-n-lock gooseneck, 4.10 gears, stock suspension, rims, and tires. Still a work in progress. Any questions or suggestions are welcome! |
04-19-2023, 10:53 AM | #5 |
Yes, those are factory skid plates and required the second crossmember. Trucks with transfer case skid plates also got fuel tank skid plates RPO NY1.
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
