04-26-2023, 10:53 AM | #1 |
Power Steering Fittings
In the process of hooking up AC, fuel injection and PS systems on my ‘70 C10. The March drive setup on my Gen1 SBC has a type 2 power steering pump. I’m using Russell Poweflex hose and fittings. But I’m pretty sure I have the wrong 6an adapter for the high pressure pump output. It’s the correct 16mm X 1.5, but doesn’t seem to seat correctly. No one locally has been much help, so I figured I would reach out to the forum. Apologies if there’s a thread that already covers this
Posted via Mobile Device |
04-26-2023, 11:14 AM | #2 |
Re: Power Steering Fittings
Looks correct to me
04-26-2023, 09:31 PM | #3 |
Couple of things.
Is the Russell hose rated or the pressure side of a power steering pump? Could it be the pump needs a fitting designed a for flare type fitting? |
04-27-2023, 03:30 AM | #4 |
Appreciate the response. The hose and ends are for high pressure power steering applications. And the type 2 pump doesn’t have inverted flare, but the steering box does. I have the correct 6an adapters for the box. Waiting to hear back from TuffStuff, as they have this adapter available.
04-28-2023, 12:02 PM | #5 |
The TuffStuff fitting is the answer
04-28-2023, 04:03 PM | #6 |
get this too. you can lower the pressure of your pump to your liking
https://www.borgeson.com/Pumps-Brack...cing-Shim-Kit/
Please be patient. I’m a ford guy. This is my 1st Chevy. Previous cars: 1973 mustang convertible 2003 mustang Mach 1 Now building resto mod 68 C10 step |
04-29-2023, 07:32 AM | #7 |
Thanks for that info, NJ68!
