04-30-2023, 09:35 AM | #1 |
Idler arm length
My 64 C10 has a GM power steering box and pittman arm installed by the PO, but the idler arm I assume is stock, as the steering geometry on that side is wrong. A friend says the idler arm length should match the pittman arm length, with the center link parallel to the crossmember. The current pittman arm is 5" c-c in an S shape.
04-30-2023, 10:48 PM | #2 |
Re: Idler arm length
Do you know what year your steering gear is?
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
05-01-2023, 12:35 AM | #3 |
I am having the same problem with my truck. Having trouble finding the dimensions for pitman arms and idler arms on the web and parts houses dont seem to want to do the leg work to help out. My steering box is from a mid 80's c10.
05-01-2023, 09:47 AM | #4 |
Steering box/pittman arm is from PO, looks like 70s/80s power type Saginaw. The rest (center link, tie rods, adjusters) is assumed to be stock 64 C10. This was a bought project. When I move the idler arm mount to where the center link is parallel and clamp it to the frame, it seems to steer correctly. The pics posted by bagger is very like my setup.
05-01-2023, 09:52 AM | #5 | |
I dont know for certain if an idler arm from a squarebody has the same taper as the 64 on the center link, but if it does, you could use that one. You would have to drill new holes in the frame. Or, just use the stock idler arm if its in good shape and drill some new holes where it seems to steer the best. Also, make sure your center link is attached in the correct orientation. If installed wrong, a new idler arm wont fix your problem.
05-01-2023, 09:58 AM | #6 |
C10/20/30 Chevrolet - Moog P/Ns
Pitman Arm length (center line to center line) 60-66 all 5.374" K6086 67 all not 100% sure ? 68-72 manual not 100% sure K6130 68-72 power 5.137" K6131 73-89 manual 5.157" K6142 73-89 power 5.059" K6143 Idler Arm length (center line to center line) 60-62 all not 100% sure ? 63-66 all 5.9" K14 67-82 all 5.394" K6096T 83-89 all 5.394" K6247T |
05-01-2023, 08:22 PM | #7 |
After checking RockAuto, it seems the idlers after 66 use a different mounting procedure. I also checked the earlier S10s, that use the L-shaped arms, and they mount to the inside of the frame, not the outside, making them shorter on the center link. As my initial question says, do you need an equal-length idler arm as per the pittman? If they're not, and steering is not hampered, does it matter? What are people using for an idler? Just lining things up and making the existing one work?
05-03-2023, 09:59 PM | #8 | |
And yes the center link should be parallel to the crossmember. |
05-03-2023, 11:45 PM | #9 |
Or maybe the idler arms were mounted in different spots on the frame for different years. There's a lot of parts in play here.
05-04-2023, 09:37 AM | #10 | |
05-04-2023, 05:16 PM | #11 |
Places like RockAuto sometimes give the dimensions of things like this in their description of parts. I've figured that a idler from a 80s-90s S10 4WD pretty much fits the bill, at least in dimensions. Maybe check out the local UPullit for a looksee.
