Old 05-03-2023, 11:49 AM   #1
Jasko59
'70 K5 front axle swap w/'80's Dana 44
Does anyone know what year Dana 44 front axles I can direct swap / bolt onto my '70 K5 Blazer, with no significant modifications to the assembly? I'm making the swap so I can have disc brakes on the front. I found some axles from '80's era square body K5 and K10 trucks that the seller says will work. I realize I may have to swap out the knuckles. Thanks in advance for any replies.
Jasko59 is offline   Reply With Quote
Old 05-03-2023, 01:52 PM   #2
A1971Blazer
A1971Blazer's Avatar
Re: '70 K5 front axle swap w/'80's Dana 44
anything up to about '88 but it will likely be a corporate 10 bolt...most all after about '78 were 10 bolt...
the D44 is arguably slightly stronger, but if you're not going to bash on it, the 10 bolt is fine...all have disc brakes
everything from the knuckles out will interchange with the D44...the inner axle shafts will not fit...they are slightly larger on the D44
I just did this swap on my '70 K5 using a 10 bolt from an '87 Suburban.
I added the sway bay as well...most of the 80s models will have one.
1967 C10 Step side
1968 C10 Step side
1970 Chevrolet K/5 Blazer
1972 Chevrolet K/5 Blazer
A1971Blazer is offline   Reply With Quote
Old 05-03-2023, 05:21 PM   #3
Jasko59
Attachment 2269326
Attachment 2269327
Got it. Thanks for the info, it will definitely help.
Old 05-06-2023, 04:46 AM   #4
Richard
A working axle from a 72 with disk. Sold to the good guy a while back with my rear axle. Direct bolt in. https://67-72chevytrucks.com/vboard/...d.php?t=844297
Richard
