Factory Rally Wheel Trim Rings - What metal are they made of?
Hey guys,
I finally got my hands on a nice set of GM 15x8 Rally Wheels. The trim rings that came with them have a few deeper scratches that I want to try and sand out a bit before polishing them. What kind of metal are they made of? They don't appear to be chrome so I'm hoping I can sand the metal a bit then buff. Anyone have any other advice on sanding out scratches on rings? Here's a pic with the truck with the bare steelies on it. Stock height, 235/70 tires on them for now
1971 Chev C10 - 250ci L6 w/3 speed on the floor Upgrades: Power Steering 3 Core Radiator 7 Hole Gauge Cluster Power Brakes (Incoming!!..) 1971 350 (Incoming!!..) |
![]() Join Date: Dec 2009
Re: Factory Rally Wheel Trim Rings - What metal are they made of?
Some trim rings are Stainless Steel.
If a magnet won't stick to them, they are the good ones ![]() Some Stainless ones are slightly magnetic thou. Do they have any signs of rust in the scratches?
________________________________________________________________________________________ ____________________________________________ The early bird gets the worm, But the second mouse gets the cheese 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
I just checked the 2 known oem stainless rings i have, and a high-strength magnet barely sticks to them. There are absolutely no identifying marks on the back side that identify them as stainless, or even a part number that i could see.
#4 | |
I assume they must be stainless, maybe the little bit of rust a polished off was more surface crud than the metal rusting?
There are several videos on U tube of how to sand a polish them.
Probably better than how I would Type it ![]() Yeah Without getting into Metallurgy, ![]() Different Series of Stainless has some Ferrous materials in it. ![]()
I found a decent set on a 90's Chevy van. Shallow compared to what you have but looks to
Be more original..IMO.
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 |
Stainless steel has varying degrees of nickel content, depending on the SS rating. Nickel is magnetic.
Ahh, that makes sense why it would be just a little bit magnetic! Interesting
Who Changed This?
![]() Join Date: Jan 2013
Nickel is ferromagnetic, just like iron. 300 stainless has a high chromium content which is why it doesn't corrode beyond a surface layer. And the chromium is what makes it have a very low magnetic moment (magnet sticks only very slightly). 400 series has low chrome content and is ferromagnetic.
#10 | |
This one here looks pretty good. Just searched for "stainless trim ring sanding" on YT... https://www.youtube.com/watch?v=J5vz0aLidCs -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
![]() Join Date: Dec 2013
They are stainless . Not everyone has a stand mounted buffing wheel . Harbor freight has green polishing compond and small buffing wheels to use in a angle grinder , scratches can be fixe using 400-800 grit wet/dry sand paper and then buffing . The trick to buffing stainless is high speed and heat built up from pressure . There are pictures in this thread .
![]() https://67-72chevytrucks.com/vboard/...d.php?t=765868
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
#13 | |||
I Know this is a touchy subject for some ![]() Quote:
![]() Quote:
![]() Go to Harbor Freight ![]() ![]() ![]()
#14 | |
Who Changed This?
#15 |
Thanks guys, that video was exactly what I was trying to find! Should be a fun project, a lot of work but moving through all the grits should pay off
#16 |
Okay
![]() I speak for all of us that had Input ![]() We would like to See Before and After Pictures. ![]() In my experience as a Machinist, Stainless is Difficult to machine ![]() With that being said., ![]() It is also Easy to cover up (Some /not All) a Boo Boo's with fine grit sandpaper or scotchbrite. ![]()
