05-04-2023, 06:44 PM | #1 |
Door lock
Getting lots of small things checked off the list.
Door lock was supposed to be one today. 1950 so it only has a passenger outer door lock. Never had a key so I bout a new keyed one. Replacement was easy. But it doesn't work. If I push down on inner door handle it locks the door as it should. But the key doesn't feel like it wants to turn all the way. Popped it back out. Used a screw driver of the same size and I cannot lock or unlock with the key. Thoughts?
1950 Build |
05-04-2023, 07:16 PM | #2 |
Re: Door lock
Does it work when the lock isn't in the door? Meaning, can you work the key back and forth with the lock out in your hand?
05-04-2023, 07:19 PM | #3 |
Re: Door lock
Yep. Full movement.
1950 Build |
05-04-2023, 08:46 PM | #4 | |
Re: Door lock
the key does not unlock the "push down the inner handle to lock" lock. you lock the drivers door that way, then get out the passenger side, and use the key which when locked blocks the outside handle from opening the door and when unlocked lets the handle work normally. and if you think about it, the key would have to push the inner door handle down to lock the door and up to unlock the door. there isnt any type of linkage like that. i rebuilt some 41-46 door latch assemblies and I think i have pictures of the little cam in them that just blocks the outside handle from turning. while its not the same mechanism it is the same principle. the first year that the actual key locked the mechanism was 67. even the 52-55.1 door handles with the key in the button still work by preventing the button from working, not moving the inside handle. if you were able to lock both inside handles and get out somehow, you would not be able to get back in!
the mass of men live lives of quiet desperation if there is a problem, I can have it. new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393 |
05-04-2023, 10:19 PM | #5 |
Re: Door lock
I replaced both worn out door latches with new ones. Took apart the old passenger one to find out what operated the lock. Took the new drivers side apart and duplicated in reverse the arm that has the space in the drivers side for it to lock. Just cut a lock hole in the drivers door and get it keyed the same as the rest. Wouldn't tolerate sliding across the seat every time. Took a weekend to do... but most of my psycho ideas usually take time.
Chip '51 Chevy 3600 5 window C4 Vette front/rear suspension & drive train full Rusto-Mod '92 GMC Sonoma GT VIN #0015 '91 GMC Sonoma GT extended cab 1 of 1 |
05-04-2023, 10:54 PM | #6 |
Re: Door lock
The point that Joedoe made is "THEE" point. You don't move the passenger door handle to locked and close the door, you close the door and then lock it with the key. You only lock the passenger side door with the handle when you are inside and want the door locked.
05-04-2023, 11:25 PM | #7 |
Re: Door lock
If I'm reading MATT 50 correctly, the last comment was that whatever state the inside was in, the key wouldn't do anything(lock or unlock). The entire latch may be bound up not allowing the light action of the key, but even a screwdriver isn't working. It isn't a 'linkage' that operates the key operation, it is a lever that is sandwiched in the mechanism of the latch that stops or allows the outside handle from moving. If the lever can't move freely, the lock/unlock won't work.
05-04-2023, 11:31 PM | #8 | |
Re: Door lock
05-05-2023, 12:53 AM | #9 |
Re: Door lock
excuse the thread jacking,
my '52 with push button doors, both inside handles will lock the doors, so as Joedoh suggests it is possible to lock both doors so you can't unlock from the outside. What is supposed to stop that from happening, is it a feature of the latch, inside handle or some adjustment I missed? also, both inner handles, you only have to move them a small amount from the unlocked position to trigger the release of door latch, is that normal? |
05-05-2023, 01:08 AM | #10 | ||
Re: Door lock
hmm. i read it as he locked the door with the door handle and the key would not unlock it. which it never will, was my comment, different systems. Quote:
05-05-2023, 07:45 AM | #11 |
Re: Door lock
I played with the door. Opened, closed, window down ect. The little part that does the locking looks the same on the driver door. To see it work with the door open I had to manually rotate the part that hits the latch back and forth. With the lock or a screwdriver I couldn't get it to lock. The key only moved maybe a quarter turn until it found resistance. I guess I need to pull it all out and see if anything is in a bind.
1950 Build |
05-05-2023, 08:08 AM | #12 |
Re: Door lock
nothing is in a bind, it is working the way it is supposed to. in fauxgt p[icture you can see the locking cam only has about 80 degrees to turn and lock (by blocking the OUTSIDE handle from turning) or unlock (by letting the outside handle turn normally). because it is only turning that little cam, there will be barely any resistance to it turning and it is more a "turn almost a quarter and its locked" than feeling it turn anything. it is not connected to the part of the door that turns the inside handle, and thats important too because even if you lock the door with a key you can still open it from the inside.
05-05-2023, 08:21 AM | #13 |
Re: Door lock
Using the key. Turning it as far as it can go, I would then turn the handle and the door would open. Thats when I started playing with it opened or closed and moving the different parts by hand to see how it all worked.
So, door unlocked on inside. Door shut. I can turn outer handle and open and close it. Then I use the key and I can still turn outer handle and open it.
1950 Build |
05-05-2023, 08:26 AM | #14 | |
Re: Door lock
05-05-2023, 08:46 AM | #15 |
Re: Door lock
No worries, hard to describe everything in text. I'll take it apart in the next few days I guess.
1950 Build |
05-05-2023, 02:29 PM | #16 | |
Re: Door lock
Some old manual links of interest to the general topic of locks: pre 52 shop manual link to section about locks http://chevy.oldcarmanualproject.com...51ctsm0114.htm 54 shop manual locks http://chevy.oldcarmanualproject.com...4ctsm0111.html truck owners manuals links to lock descriptions below. there are some interesting variations on how the outside key works. All versions I have seen just describe the inside handle as 'to lock either door from the inside it is only necessary to move the inside remote control handle forward (the '48 version says 'up'). So none really answer my question about locking yourself out. 51 owners http://chevy.oldcarmanualproject.com...er/51tom11.htm 52 owners manual http://chevy.oldcarmanualproject.com...er/52tom11.htm 53 owners http://chevy.oldcarmanualproject.com...er/53tom11.htm lock cylinder key has different action for '52 vs '53, my '52 must have '53 lock cylinder |
05-05-2023, 07:03 PM | #17 |
Re: Door lock
i have a 54 in the driveway and totally forgot my "i will try in the morning" until you responded.
both drivers and passenger doors unlock after shutting the door if you push the inside handle down (locking it) with the door open and then shut the door. the interior handle moves up almost imperceptibly but its enough to unlock the door, I had no issue opening a "locked" door after shutting it. I tried it several times on both sides. I have a 49 at the shop that still has doors I will try it on a drop handle too. this makes sense, too, because we dont have 10,000 threads from different people about locking themselves out. the "key unlocks the inner handle" myth would be a lot more prevalent if it was possible to lock an open door with the inside handle.
05-05-2023, 07:07 PM | #18 |
Re: Door lock
Maybe the inside handle adjustment is more subtle that I thought. I will play with this some more.
thanks! |
05-06-2023, 04:38 PM | #19 |
Re: Door lock
Here is what I found:
1952* If either door is closed and you lock it from inside, it can't be opened or unlocked from outside. Passenger lock mechanism wont let you lock with inside handle if the door is open. If Driver's door is open and you lock the inside handle, when you close the door the lock mechanism unlocks but does not move the inside handle or the pin it connects to on lock. Thanks again Joedoh for the assist. *1952 doors with push button exterior handles. Maybe the exterior handles are from 1953 given how the key operates (see manuals linked above). Locks and inside remotes are most likely 1952, but could be any year as I salvaged parts from various trucks years ago. Last edited by leegreen; 05-06-2023 at 11:51 PM. |
05-06-2023, 08:47 PM | #20 |
Re: Door lock
One thing about it, you aren't going to lock the keys in the truck.
