Old 05-08-2023, 03:40 PM   #1
BigElittleg64
BigElittleg64's Avatar
Vent window install
when you are reinstalling the vent window assemblies is the seal designed to be pressed into the door around the perimeter of the frame?
BigElittleg64 is offline   Reply With Quote
Old 05-08-2023, 06:41 PM   #2
bhap
bhap's Avatar
Re: Vent window install
I think the seal is made with a “flap” that should be pulled out of the door so that it rests on the door surface and creates a seal. Rather than tucking it in, use your tool to lift the seal out and work your way around the window. Will keep some of the rain out of the door and give it a more “finished” look.
bhap is offline   Reply With Quote
Old 05-09-2023, 03:06 PM   #3
BigElittleg64
Thanks bhap for the help. That is what I was thinking as well.
Old 05-09-2023, 06:33 PM   #4
AcampoDave
AcampoDave's Avatar
On mine, the flap is inside the door
AcampoDave is offline   Reply With Quote
