05-08-2023, 04:20 PM | #1 |
Wheels spinning when in park
EDIT: After pulling off the pan I saw that my new steering column was shifting te wrong direction and I needed the move the distal lever from the 3pm position to the 9pm position. Before I had pulled off the pan, I realized I was starting the truck in D2 and could never even reach part because the linkage doesn't allow for the extent of the range needed to get to park. I'll have to replace the linkage in the future that allows for a greater range. In addition to this, my np203 won't go into the position closest to the seat. SO when I moved 1 notch from the seat thinking I was then in high, it was in neutral. And I had no clue that that allowed the drive shaft to spin until you all helped me out. Thanks. I got it all put back together today and it is working perfect.
I've got a 77 or 78 K10 chassis. I've just put in a 700r4 and ididit column recently so right now I'm trying to adjust the linkage since I felt like the truck was trying to pull forward while in park with my foot on the brake. Since I felt like this was happening, and because it just seemed like a safer and easier way to go, and because I also wanted to see if the 4x4 was working and to see if i have an anytime kit, I pulled off the wheels and put the truck on 4 jack stands. So, while in park (transmission shaft rotated counterclockwise if facing the driver's side of the transmission) my driver's rear wheel is spinning as if it's in drive. When I put it in neutral the passenger rear wheel is spinning. I bought this truck, hauled it on a trailer, had the crate engine and transmission put in and have never driven it except on and off the trailer before parking it and then swapped out the steering column.
1971 C10 manual cab. 76 4x4 chassis. Cut short frame. Carbureted Blueprint 350, automatic 700r4. ~ James Last edited by K10-Kansas; 06-03-2023 at 07:37 PM. Reason: solution was found |
05-08-2023, 06:59 PM | #2 |
Re: Wheels spinning when in park
Does the driveshaft turn or just one of the wheels spin?
05-09-2023, 06:36 AM | #3 |
Yes the drive shaft is turning
1971 C10 manual cab. 76 4x4 chassis. Cut short frame. Carbureted Blueprint 350, automatic 700r4. ~ James |
05-09-2023, 07:43 AM | #4 |
Not an expert but many postings about the 700R4 state that unless the shift cable is properly adjusted, transmission damage can happen in just a few miles. I have one that I was considering installing in my C10 so did some research.
While in reverse, does the shaft and rear hub turn the other way? Do things try to turn while it is in neutral? Not really related to the transmission issue, check the brake adjustment on the non-turning rear wheel. Might be a bit snug since only the other wheel is turning. |
05-09-2023, 09:57 AM | #5 |
If the driveshaft spins with the engine running it's not in park.
Turn it off. Disconnect the column to trans linkage at the trans. Rotate the trans lever to the first (park) detent. Try to rotate the shaft. It should either not rotate or it may rotate a slight bit and then you will hear / feel the park lock pin engage and should not be able to rotate the driveshaft. If it keeps rotating you either are not in park (are in D1, the other last detent) or something is broken inside. Rotate the lever back the other way completely and check again. Once you have located park set the column to park and hook up the lever. My bet is it's not being shifted fully into park.
1987 2 ton 1982 250/TH350 beater in progress Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping Plus a mess o' tractors |
05-09-2023, 11:49 AM | #6 | |
05-09-2023, 07:05 PM | #7 |
I disconnected the steering column shift rod from the transmission. I can manually spin the drive shaft counterclockwise and clockwise in any gear with the transmission shift rod spun all the way clockwise all, all the way counterclockwise and every gear in between. Does this mean my transmission is screwed up?. It was working fine before I parked the truck and swapped out the steering column.
05-09-2023, 07:46 PM | #8 | |
05-09-2023, 09:52 PM | #9 | |
The turns by hand in all gears sounds like the transfer case is in neutral. |
05-09-2023, 10:05 PM | #10 |
Yeah, the detent/tv cable has to be adjusted well or it can damage the transmission quickly. I'm sure mine was adjusted well and the truck was only driven 30 feet. Just from the car hauling trailer to the garage.
05-09-2023, 11:15 PM | #11 | |
It's just a little pin that keeps the driveshaft from turning when in park. That's why you're supposed to use the parking brake also, which I don't. If you have ever shifted into park before the truck stopped completely then you would hear a clicking like noise from the pin trying to lock. Sometimes when cars are towed without the keys and they have to pull it to hook it up it will click instead of dragging the wheels. The transmission should work fine other than having two neutrals. The TV cable would not affect the parking pin.
05-09-2023, 11:24 PM | #12 | |
Here's a picture although I'm not sure how helpful it is.
05-11-2023, 04:29 PM | #13 | |
Is there a chance that me shifting the 4x4 around a bit could have messed something up? Or could it break while starting and stopping the car hauler on the 3 hour drive home? Maybe it wasn't in park when I started the truck after putting in the column and then I damage the pawl while moving the gear selector with the engine running?
05-21-2023, 08:44 PM | #14 |
Hi! is this park?
05-22-2023, 06:54 AM | #15 |
Yes. That’s park. Is the small linkage rod behind the stepped plate connected at both ends?
Edit: here’s a thread that might help: https://www.jalopyjournal.com/forum/...ething.843963/ Last edited by ACS; 05-22-2023 at 07:01 AM. |
05-22-2023, 09:02 AM | #16 | |
I'll check when I get home. Here's a picture I took yesterday. There's a chance that when I started the truck it was not in park. I may have had the linkage mis adjusted after putting in the new steering column. Also my brake line blew while trying to get the truck started so there is a chance I shifted without being able to stop the wheels from turning before I did so. I had the truck up on 4 stands with wheels off
1971 C10 manual cab. 76 4x4 chassis. Cut short frame. Carbureted Blueprint 350, automatic 700r4. ~ James Last edited by K10-Kansas; 05-22-2023 at 09:18 AM. |
05-25-2023, 07:05 AM | #17 | |
05-25-2023, 09:04 AM | #18 |
From the TM on my M1008 CUCV(military version of an 84 K30). It has the NP208. I would think the NP203 works similar.
"If transfer case control lever is in “N” (Neutral), transfer case is disengaged and shifting the transmission gearshift lever to “P” (Park) WILL NOT stop the truck from moving." |
05-25-2023, 01:00 PM | #19 |
Yes, the transfer case is in neutral or disengaged. Would be the same if the transfer case was 'in gear' and the transmission was in neutral.
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
05-25-2023, 09:18 PM | #20 | |
I'm new to all this so just trying to figure out if something is broken or if i just don't understand how it works.
05-25-2023, 09:27 PM | #21 | |
05-27-2023, 08:44 AM | #22 |
The transfer case has to be in one of the drive modes to engage the transmission . Neutral was to flat tow short distances as it disengages the front and rear axle/driveshafts from the drivetrain .
05-27-2023, 08:49 AM | #23 |
Ok thanks. It seemed like last week when I was messing with it, there was only 1 position where the transmission would behave like it was in park. My transfer case is only resting in 4 noticable positions as near as I can tell. And it seemed that only 1 of those positions allowed for park. With the info I've gotten here. I'll have a better go at it today.
06-03-2023, 07:37 PM | #24 |
