Old 05-08-2023, 04:42 PM   #1
8man
Rear speaker mounting
How are you mounting rear speakers to these trucks.
The 48 had some custom panels welded in place when I got it. They followed the curve of the side and back of the cab. Only problem with them was I had to make a spacers to set the speakers out from the metal piece because the speaker was hitting the side of the truck and wouldn't bolt in. I can't find them anyplace.
I've seen the ones from LS Fabrication, but don't know how they install and/or if there are other problems with them.
Thanks.
8man-aka Robert
1948 on a S10 Frame, small block with a carb
1954 Cab, 53 Front and Bed, 50 Doors, S10 Frame, Power TBD
Build thread: "]http://67-72chevytrucks.com/vboard/showthread.php?t=746899&highlight=wife%27s+48[/URL]
[/URL]http://67-72chevytrucks.com/vboard/showthread.php?t=840204
8man is offline   Reply With Quote
Old 05-08-2023, 06:42 PM   #2
rnrdthefox
Re: Rear speaker mounting
Curious about what others will say.
I haven't got to this point yet, but I was thinking about panel bond but I need to talk to a couple of the stereo shops. I want kick panel pods and pods in each rear corner molded to the curve of the truck. I've seen pictures with guys doing the mdf and fiberglass to fit the contour and building structure into it for the speakers of choice. Then it gets upholstery.
rnrdthefox is offline   Reply With Quote
Old 05-09-2023, 09:31 AM   #3
Tempest67
Tempest67's Avatar
Here is what I did,
start with welding a 'tack strip' to the rear door frame. (used to attach the speaker panel)
then bend a piece of 18 gauge to form the rear corner and attach to 'tack strip' and the rear support strap.
Cut the 6x9 hole, and make a 'lid' for the enclosure,
then insulate/carpet the entire piece up to the 'chair rail' as the carpet will 'bend' easily to fill the corner.
do that to both sides, and make a rear panel (1/16 mdf) that butts up to each speaker enclosure
I also added 2, 4 inch round speakers to the dash.
Hope this gives you some ideas
Tempest67 is offline   Reply With Quote
Old 05-09-2023, 09:33 AM   #4
Tempest67
Tempest67's Avatar
oops, here is the dash with the speakers
Old 05-09-2023, 09:43 AM   #5
8man
Thanks Tempest. That looks good.
8man-aka Robert
Old 05-09-2023, 09:47 AM   #6
rnrdthefox
Tempest, Nice corner work. I like the speakers behind the dash grill. I want to do the same for a mono center channel. What kind of fabric did you use across the inside of the grill?
Old 05-09-2023, 10:15 AM   #7
Tempest67
Tempest67's Avatar
Hopefully that will give you some ideas.
My work certainly wont win any prize, but it looks OK to me, and the sound deadening is really good
'fabric behind the grill ? ha ha, believe it or not, I had a wire mesh trash can from a dollar store lying around, and I cut it up and used it to give the "grill' look.
Old 05-09-2023, 10:16 AM   #8
8man
That's genius!
8man-aka Robert
Old 05-09-2023, 10:24 AM   #9
Tempest67
Tempest67's Avatar
genius ?
Old 05-09-2023, 10:31 AM   #10
rnrdthefox
Lol!
Old 05-09-2023, 12:23 PM   #11
thaBrad
I am currently trying to make my rear speaker enclosures. What does NOT work is 1/8" and 3/16" hardi board panels. They will not curve tight enough to the curve of the truck. I tried scribing slits in the backside and that makes it break when you try bending it. I'm planning next to use sheet metal and curve it fastening to the truck curve. Then glue/screw plywood standoff to the metal for the speaker to mount too, then upholster it. I'll post pics when complete if it works.
thaBrad is offline   Reply With Quote
Old 05-09-2023, 01:09 PM   #12
Tempest67
Tempest67's Avatar
I had the same problem when making my headliner. The curve over the door was too much and the 1/8 MDF would break. So I ended up gluing the vinyl on a piece of metal that I shaped.
Old 05-09-2023, 05:24 PM   #13
jweb
jweb's Avatar
I didn't make a back since 6x9's are designed for use with or without a box. Seems to work fine for me.
1951 Truck, LS1/4L60
1964 Suburban, current project
jweb is offline   Reply With Quote
Old 05-10-2023, 02:30 PM   #14
mr48chev
mr48chev's Avatar
The metal panels inside the corners of real 47/48 cabs are factory reinforcement because of the center cab mount on the rear of the cab. That just makes it a bit more challenging to put speakers in the corners of those cabs.
I like Tempest67'sahole setup though. That has the makings of a nice setup.
My ongoing truck projects:
Old 05-10-2023, 05:19 PM   #15
8man
Mr48, thanks for the info on those metal corners.
8man-aka Robert
