Old 05-10-2023, 12:30 PM   #1
sdwolff98
Turning Wrenches Daily
1962-1966 GMC hood marker lamp rebuild thread.
Hey Guys
i see this on a regular basis on facebook and other sites. Asking how to take the GMC hood lamps out and rebuild them. to date I have not found the rivets as of yet so went another route and it worked good on my truck.
first thing is the tabs. you need 2 tools to get them out a flat blade a short prybar. Flat blade goes under the lip of the lens prybar is for the tabs that hold the housing in place. gently and I mean gently depress the tab and use the flat blade to get it unseated
pictures to show
Sean
Work! Play! Work work work! Money to play with. 64 GMC, 66 burb 4x4, and now 64 1ton money pits......ahhh life is good. Upcoming move back to Texas Dallas bound we are this september!!!
1964 GMC I1500 2wd (my baby) 8.1 allison 6 spd conversion Aka Smurf http://67-72chevytrucks.com/vboard/s...d.php?t=438342
2016 Ram Big Horn 4WD parts hauler
2010 Chevy HHR wife new car after the circled problem blew up!!!
1981 Ram D150 /6 auto Wife's sunday driver
Living outside Gladewater Texas now working in Longview at the hospital there
future project toys:
1966 Chevy K14 carryall aka Smurfette future project 283/auto overdrive http://67-72chevytrucks.com/vboard/s...d.php?t=551867
sdwolff98 is offline   Reply With Quote
Old 05-10-2023, 12:34 PM   #2
sdwolff98
Re: 1962-1966 GMC hood marker lamp rebuild thread.
ok once they are out there are 4 rivets. as of yet have had a very hard time finding the correct replacements. the rivets in the housing are hard to find so if someone knows what sixe they are please add to this thread!! I used a small drill to take them out. if your lense are in good shape be gentle and they will not crack
Sean
Old 05-10-2023, 12:40 PM   #3
sdwolff98
the new lenses came with rivets but I had to get a second set because for some reason maybe technique I cracked the lenses installing them grrrr. So on second set went with some hobby shop airplane screws lol . 2-56 ones with nylock nuts on the back side. worked great. did have to trim some reliefs in the hood for the nuts tho. Replacement lense do come with gasket swhich is nice to see. here are the finished install pics
Sea
Old 05-10-2023, 07:28 PM   #4
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
so what LED did you use? interested in the info.
Sick5 is offline   Reply With Quote
Old 05-10-2023, 08:51 PM   #5
sdwolff98
sick5 I built those. they are cree 12volt 20cm disc led xhp70's. I used a resistor to drop the current to 2 amps lol. first time I powered one up it exploded off the disc and flew across my garage rotflmao!!!! that was at 10amps lol.
Sean
Old 05-11-2023, 12:51 PM   #6
short&wide65
Great thread! I don't want to rivet my replacements and my lenses didn't come with any since I bought them years ago (back when there were still U.S. made) and don't want to damage them.
1965 GMC 910 Short Fleetside. 230 CI 4-speed.
short&wide65 is offline   Reply With Quote
