Old 05-11-2023, 02:45 PM   #1
Nuke64
Rear shock relocation question
1964 Shorty Stepside, I just purchased the CPP relocation brackets, but they didn't co.e with any instructions. I have 4" drop springs, and wondering if I can just purchase 4" drop shocks, or if the brackets require a shorter/ longer shock? Just seeing if anyone else has installed these before. Thanks in advance.
Nuke64 is offline   Reply With Quote
Old 05-11-2023, 04:25 PM   #2
scottofksu
scottofksu's Avatar
Re: Rear shock relocation question
Personally, I would recommend that you install the relocation brackets and then cycle the suspension from full droop (i.e., lift the truck from the frame and let the axle hang) to full stuff (e.g., with the springs as fully compressed as you can get them) measuring at both extreme the distance between the upper and lower shock mounts. This will tell you the length of shock you need exactly versus just a guesstimate.
Travis' Tribute Truck - 65 C10 Frame Up Restoration
http://67-72chevytrucks.com/vboard/s...d.php?t=495073
scottofksu is offline   Reply With Quote
Old 05-11-2023, 04:45 PM   #3
vin63
It's Better With Nitro
vin63's Avatar
Not sure if this pic helps...this is at full compression. As Scott mentioned, I measured based on my desired ride height, and then measured suspension at full compression/extension to order my shocks based on the manufacturer rebound/extended and ride length specs.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
