Old 05-13-2023, 03:13 PM   #1
TX3100Guy
TX3100Guy's Avatar
Jigsaw puzzle - Grille
Keep in mind that when I acquired this truck, both the front fenders, inner fenders, and the grille parts were loaded in the bed of the truck. I've never seen them on (or taken them off myself).
Now I'm in the process of putting it mostly back together. I had re-installed the inner fenders and had test fit the grille and the lower grille section that mounts to both sides of the radiator support. I began to wonder how I was going to attach the grille to the hood latch section that mounts to the top of the radiator support and to the lower section of the grille/radiator support.
As luck would have it, I had to take it all apart and remove the inner fender on the drivers side. Why you ask? It seems that I forgot to leave the engine with the number one cylinder at TDC before I reinstalled the magneto that this truck came with. As a result, I was forced to remove all those body sections and the Vintage Air compressor and remove the radiator so that I could get to the crank pulley to crank the engine to #1 TDC.
Now that I have all these parts laying on the shop floor, I'm wondering what the correct way to attach the grille to the upper and lower sections that are bolted to the radiator support. Also it seems that the outer fenders mount to the body sides using the same captive nuts as the inner fenders. Is that the case?
Name:  Screenshot 2023-05-13 at 2.09.03 PM.jpg
1953 Chevy 3100 - 5 window 1/2 ton pickup
My 1953 Chevy Work-In-Process Photo Gallery
"I don't have a carbon footprint, I drive everywhere."
TX3100Guy is offline   Reply With Quote
