Old 05-13-2023, 07:41 PM   #1
forestb
forestb's Avatar
Upper control arm bolt.
I found that my upper control arm nut has completely unthreaded and come off. I don’t know if it’s possible for the rod to completely come out but I think God that it didn’t fall apart on the freeway. Does anyone know where I can get this nut and and what it should be torqued to? Also should I put some locktight on it or something to keep this from happening again?
forestb is offline   Reply With Quote
Old 05-13-2023, 07:43 PM   #2
forestb
forestb's Avatar
Re: Upper control arm bolt.
Sorry here are the photos.
Old 05-14-2023, 07:27 AM   #3
LMC Truck has it.
https://www.lmctruck.com/1988-98-che...-2-wheel-drive
Not sure about local parts places sell the nut, but Dorman makes a control arm replacement bolt kit.
Old 05-14-2023, 01:05 PM   #4
Just call me Sean
Just call me Sean's Avatar
That must be 4wd, as my 2wd doesn't look like that. I got mine from the junkyard because an offset washer was missing. My S10 has that style control arms and AutoZone shows a shaft kit with the nuts. I don't see why they wouldn't have the same kit for yours.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 05-14-2023, 03:45 PM   #5
95 S_Trucker
95 S_Trucker's Avatar
That’s not a GMT400. The shock is mounted to the rear and the steering box is on the outside of the frame. Ask a mod to move this to the right section.
95 S_Trucker is offline   Reply With Quote
Old 05-14-2023, 09:17 PM   #6
forestb
forestb's Avatar
Sorry I posted this in the wrong section. This is for a 77 c10. Thanks for all the help. I just posted it in the correct section.
