'72 Factory AC - No 'hi speed' on fan
The heat/AC fan on my '72 C10 only blows low and medium. After searching this site, i found a couple threads that said to replace the relay under the glove box. I did that today ($19 from O'Reillys) and still no Hi speed on the fan. When I move the switch from Med to high, I do hear a click in the relay. I believe that the resistor controls fan speed on low & medium, and is bypassed completely for high speed. Not sure where to go from here.
"Life is too short to use cheap zip ties" 64 C10 SWB 71 C10 LWB 72 C10 LWB |
![]() Join Date: Apr 2016
Re: '72 Factory AC - No 'hi speed' on fan
The 12 gauge orange wire that powers the fan through the relay plugs into the CIG position on the fuse panel. Check that it's still plugged in. Measure voltage with a multimeter at the heavier-gauge orange wire at the relay.
Diagram without anti-dieseling relay Diagram with anti-dieseling relay ![]() |
[EDIT] Dang it !!!! djmlambert, you beat me to it and posted while I was still typing..
![]() ![]() ![]() A complete AC electrical system wiring diagram can be found in the Heater/air conditioner section of the GM service manual for these trucks.. |
![]() Join Date: Dec 1999
I had remembered the high speed on A/C tied in as mentioned but was not sure as it has been a while. So other than connections, the fuse for the cigarette lighter is the first thing I would check. I always keep to KISS it first. "Keep It Simple Stupid".
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
