05-19-2023, 11:58 AM | #1 |
will this PCV work
The Mr Gasket push in breather goes in the opposite valve cover.
My friend has some that are more of a little open cylinder filter push in breather I could substitute. anyhow thoughts on this set up. |
05-19-2023, 01:23 PM | #2 |
Re: will this PCV work
Resized images
05-19-2023, 01:33 PM | #3 |
not sure what actual PCV valve you have, but otherwise the plumbing will work.
With that said I have read, due to rotation of engine, the PCV should be PS and breather DS. You could just flip the VC to other sides if you wanted to have it plumed that way if the VC holes are specific to PCV and breather size ports |
05-19-2023, 01:35 PM | #4 | |
05-19-2023, 01:35 PM | #5 |
The idea of a PCV system is to prevent (or help control) crankcase vapors.. Fresh air enters through the vented cap on the valve cover opposite the PCV valve. The vapors pass through the valve and into the intake manifold with the incoming fuel/air charge. The vapors are burned along with the fuel. This incoming air must be filtered so as to not introduce dirt and other unwanted debris. I don't know what the other "little open cylinder thing" you're talking about, but the filter you have in your hand will do just fine provided it fits the valve nice and tight.
05-19-2023, 01:54 PM | #6 |
68 C10 Longbed
The setup you propose will work, but the cleaner way to do it is to return the spent gases through the air cleaner and back through the engine if possible. Many aftermarket air cleaners have an attachment that can be attached under the air cleaner base itself, sometimes those are included in the box with the unit or available as an option. The proposed set up will work as stated but will also create a bit of a mess over time if not regularly cleaned as the gasses will release into the engine compartment around the top of the valve cover.
05-19-2023, 01:55 PM | #7 |
05-19-2023, 01:58 PM | #8 | |
68 C10 Longbed
Here is a pic of what I was suggesting by returning back into the engine. |
05-19-2023, 03:15 PM | #9 |
The correct PCV itself is important so it does not allow too much crankcase pressure to build compromising either engine seals or causing oil consumption.
The way I have my PCV plumbed is the "breather" hose goes into air cleaner base, not the PCV draw hose. IMHO you do not want to have the draw (PCV) hose going into carb unfiltered as that just adds crud inside carb. Plumbing it to base of carb it does not go "through" it but instead directly into intake manifold. A stand alone "breather" in VC like OP has is perfectly fine vs using the air cleaner base and IMHO what I do on V8. My L6 though I have the breather plumbed to base of air cleaner as otherwise a VC breather for my 6 cyl would be sideways and weep some oil out onto exhaust manifold |
05-20-2023, 06:51 AM | #10 |
68 C10 Longbed
The PCV system recirculates expelled air & fuel gases that has escaped past the rings into the crankcase and is unavoidable. The smaller hose is attached to a pcv valve inserted through a grommet on top of a baffled valve cover hole on the drivers side. This smaller hose is then routed from the pcv valve to a pcv port located at the base of the carb. THEN from there a 2nd larger pcv hose is attached using another grommet and some type of fitting into the top of the passenger side valve cover baffled hole and out, this 2nd hose is attached from the valve cover to the base or side of the air cleaner which completes and allows the correct circulation of pcv system. These spent gases should travel through a spark arrestor before exiting into the carb.
You can also install into the valve cover push in filtered breathers as typically seen on modified engines. Last edited by ghackett1; 05-20-2023 at 07:44 AM. |
05-20-2023, 10:06 AM | #11 | |
Location: Herculaneum MO (20 minutes south of St. Louis
67 C10 283 T5 swapped longbed fleetside = wife's daily driver 67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck 67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD 72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck Can you tell we are fans of longbed fleetsides & 67s Chris |
05-20-2023, 11:21 AM | #13 | |
68 C10 Longbed
05-20-2023, 10:05 PM | #14 |
>>Crankcase gases are never intended to be drawn through the carb, and in fact this only happens on an engine with excessive blowby.<<
During WOT (wide open throttle) manifold vacuum is at a minimum and at the same time, blow-by is at its maximum. During this event, pressure above the carb, as to say, between the mouth of the carb and the air cleaner, will be low and the increased pressure in the crankcase, will cause crankcase fumes to travel into the air cleaner and through the carb. During idle and cruise, the high manifold vacuum pulls the filtered air from the air cleaner, into the crankcase, out of the crankcase, through the PCV Valve, then into the intake manifold. Not all carbs have a vacuum port for the PVC System. Sometimes a vacuum port in the intake manifold is provided for the PCV System. When you have a valve cover breather, you have what is called an OPEN PCV System. During WOT, crankcase fumes are expelled out into the atmosphere. A CLOSED PCV System is fully contained and does not expel crankcase pollutants out into the atmosphere.
'67 GMC 2500, 292, 4spd, AC |
05-20-2023, 10:21 PM | #15 | |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" |
05-21-2023, 06:42 AM | #16 | |
68 C10 Longbed
