05-23-2023, 03:10 PM | #1 |
serpentine belt system
I've got this serpentine belt system on my truck. it's a 5 rib system and I thought it was from a late 70s truck. I recently discovered that is not correct while I was looking at AC compressors. The compressors for these years have a single groove belt. Can someone identify this system? here's a picture before I installed it.
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing. |
05-23-2023, 03:36 PM | #2 |
Re: serpentine belt system
Those are OE GM 88-94 brackets from 4.3; 5.0; & 5.7l V8 cars/trucks/Burbs.
Those particular brackets are for a smog pump optioned vehicle.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 05-23-2023 at 03:42 PM. |
05-23-2023, 05:50 PM | #3 |
Thanks Scotti, I guess they are a little newer than I thought. I actually modified mine by removing most of the smog pump mount while retaining the strength. This all came about when I started looking at AC compressors.
05-23-2023, 07:16 PM | #4 | |
Earlier/pre-93 version....
