Verifying a Posi Differential unit?
I’m starting a search for a Posi Differential for my 70 C-10 (I’m currently running the original “One Wheeler” with 3:73 gears)
While I’m at it with the upgrade, I plan on installing a more Highway friendly Ring and pinion gear set. Other than happening upon a unicorn truck, sitting in a yard with the Posi Rear option showing on the SPID, How do I verify that I’m getting an actual Posi unit? Are there casting numbers on the rotating assembly, or are there numbers stamped on it? In either case, where would these numbers be? I know these are a lot of questions but I just don’t want to get “took” out of ignorance. I’m hoping someone would have a picture of a Posi rear end with the cover off to show the gears. Thanks in advance Last edited by custom10nut; 05-26-2023 at 11:26 PM. |
![]() ![]() Join Date: Jan 2005
Re: Verifying a Posi Differential unit?
Here are some photos of an original factory Eaton posi unit and a new Eaton unit (19556-010). Both of these are series 4 size carriers for use with standard thickness 3.73 or 4.10 gears. If you want to go with 3.07 or 3.42 gears, then you will need a series 3 size carrier.
The posi carrier has the easy-to-spot springs and plates in the center of the carrier, whereas an open carrier will not. I'm not sure about the casting numbers for original units, but here is a new Eaton series 3 carrier: https://www.summitracing.com/parts/etn-19587-010 Edit - It appears that the casting number for a factory series 3 posi carrier was 32212. https://www.stevesnovasite.com/threa...ential.411706/ Last edited by pjmoreland; 05-27-2023 at 02:06 AM. |
without looking at the diff itself, spin the PS wheel/drum forward. If DS also spins forward, its a Posi. If it spins backwards its peg leg
You can count how many times the pinon rotates when you turn the PS wheel. 1 revolution. Just over 3 turns would be 3:08. 3 3/4 turns, 3:73, etc for a posi rear end. |
#4 | |
This is exactly what I was asking for. I found a “Complete Unit” with 3.42 Ring and Pinion on Amazon. It’s from Yukon, and has good reviews. I figure by the time I find an original unit, rebuild it, and buy the new gear set, I may be further ahead going with the new. |
![]() Join Date: Dec 2009
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
![]() Join Date: Aug 2015
I did this test on mine and thought it was one legged. When I pulled the cover a bunch of friction plates from the posi fell out. A rare occurrence but it can happen. Pulling the cover is best if possible.
Steve/NH 1967 K10 327 Short Bed Stepside 2008 F350 Power Stroke 2007 BMW X3 2020 BMW 540xi 1995 Harley FLSTC |
yeah looking inside is best. the spin the axle thing is a quick way to see if it is a posi if there is just a bunch of rear ends pulled from trucks at junkyard.
![]() Join Date: Feb 2002
I paid about $350 for a diff shop to pull the 1968 posi unit out from a T-Boned 3.73 rear end and rebuild it.
I intended to put it in my rebuilt 3.73 rear differential after the 500 mile break-in run, but now I find my propshaft also got bent in the collision, so I have to get that squared away, first.
#9 | |
![]() Join Date: Mar 2005
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
#10 | |
https://www.quickperformance.com/GM-...e_p_20373.html |
