Old 05-30-2023, 02:40 PM   #1
Johnl48
Soft brake line clips
Anyone have an answer to this ? I got braided lines for for the front disc conversion but the frame is too thick to get the clips on. Someone suggested a hose clamp on The back end but I practically would need to take the motor out to get to them to do that
Old 05-30-2023, 04:43 PM   #2
LS short box
Re: Soft brake line clips
Maybe an "L" bracket of some sort that is 1/8" steel material fastened to the frame instead of going thru the frame. No hose clamps for me for anything brake wise.
LS short box is offline   Reply With Quote
Old 05-30-2023, 04:48 PM   #3
Johnl48
Actually a good idea. I've seen that on vehicles before where the fitting comes thru the frame to the L bracket where the soft line is attached too Intead of behind the frame.....back to welding...thanks
Old 05-30-2023, 05:14 PM   #4
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
You need a set of these... https://www.speedwaymotors.com/Speed...ose,45896.html You also need to know where to locate them. The drum brake trucks are located on the rear of the crossmember where the disc trucks are located on the front of the crossmember. Do your research and study the factory front disc trucks...
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 05-30-2023, 07:24 PM   #5
Johnl48
Made a couple of these up. I'll get them painted and either spot weld or bolt them to the frame
Old 05-30-2023, 08:25 PM   #6
dmjlambert
dmjlambert's Avatar
I would like to see pictures of the final attached product if you can, please. What truck model and year is it going on? What shape is the hole where the hose is mounted? I bought bolt-on clips and modified them to mount the hoses in the 71-72 position in front of the crossmember, when I converted my 69 C10 from drum to front disc brakes. But I'm not entirely satisfied with how it turned out and will probably improve it in the future.
dmjlambert is offline   Reply With Quote
Old 05-30-2023, 08:40 PM   #7
Johnl48
1970 c20. I'll post some pictures tomorrow when I'm done
Old 05-31-2023, 08:28 AM   #8
Johnl48
Here's what a came up with
Old 05-31-2023, 12:09 PM   #9
kwmech
Perfect! That is what the factory did on the later model 4xs
Old 05-31-2023, 11:09 PM   #10
Ironangel
Ironangel's Avatar
Looks good, I didn't realize you had a 4x4...
"Two Seventy Two's"
02 3/4 ton Express
