Old 05-31-2023, 01:32 AM   #1
Jabes1
Jabes1's Avatar
HEI power wiring...
I have a 74' with HEI ignition. The factory HEI wiring is completely gone. I have it powered incorrectly and its melting the insulation on a tan wire Im using from the firewall bulkhead.
I would like to properly wire the Positive + power supply to the coil. Looking at the schematic (my interpretation) the + is a 20G Y (Yellow) labeled 20Y 7A which splices to 20Y 7B. The 20Y 7B looks like it attaches to the R terminal on the starter solenoid. Is this correct?
From 20Y 7A it also splices off to 20 P/B 3. What is P/B? is it pink or blue or purple or blue? This wire then appears to terminate at the firewall bulkhead engine harness terminal 3.
The schematic also calls for a 1.35 Ohm resistor for the V8 engine where is splices at 20P/B 3. Do I need the resistor?
Basically do I just need to run a wire from the + Terminal on the coil to the R Terminal on the Starter Solenoid, add in a splice wire back to the number 3 terminal on the firewall bulkhead engine harness?
Welcome to my build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=574370
Jabes1 is offline   Reply With Quote
Old 05-31-2023, 02:42 AM   #2
Just call me Sean
Just call me Sean's Avatar
Re: HEI power wiring...
This one is easier to read.
Originally Posted by Early Cuyler
Fights begin, fingerprints are took, days is lost, bail is made, court dates are ignored, cycle is repeated.
Just call me Sean is offline   Reply With Quote
Old 05-31-2023, 07:53 AM   #3
cadillac_al
Pretty interesting, my 74 still had points ignition.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 05-31-2023, 08:12 AM   #4
geezer#99
geezer#99's Avatar
As did mine Al.
All the wiring is gone for the hei because it never existed.
All you need is a dedicated 12v power source for the hei. Either from a 12v spade on the fuse box or from the ignition switch.
The yellow wire and resistance wire are not needed for an hei.
geezer#99 is online now   Reply With Quote
Old 05-31-2023, 12:25 PM   #5
406 Q-ship
406 Q-ship's Avatar
1974 would be a points ignition system. If you are converting to HEI then you need to replace or route around the resistor wire and up grade to 12 ga wire. I usually will run a bypass wire from the bulkhead connector and where it plugs the original resistor wire in the bulkhead connector. The yellow wire that runs down to the starter is the R wire that supplies power to the coil in cranking. Early ignition switches did not allow power to the ignition system when cranking the engine.
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride!
Where patience fails, force prevails
Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle."
406 Q-ship is offline   Reply With Quote
Old 05-31-2023, 01:34 PM   #6
MJN
MJN's Avatar
My '74 was also points but I converted to HEI. I removed the factory distributor power wire from a ~76 parts harness I had and replaced the resistor wire my '74 had. Easy swap and looks factory since I used factory wiring.
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 06-01-2023, 07:24 AM   #7
Jabes1
Jabes1's Avatar
Originally Posted by geezer#99 View Post
As did mine Al.
Okay... this makes sense. I've owned the truck since I was 16/17 and have had the HEI wired this way since I got it. I just recently upgraded to a more powerful coil and maybe thats why its melting the insulation.
Old 06-02-2023, 06:26 PM   #8
VWNate1
VWNate1's Avatar
Post HEI Power & By-Pass Wiring...
" Early ignition switches did not allow power to the ignition system when cranking the engine. "
Not sure where you ever got that idea .
The entire point of the second terminal on the starter solenoid was to by pass the calibrated ignition wire from the key switch when cranking so the spark was stronger .
I add HEI systems to everything and my simple method is one of those tiny cube relays that's rated for 50 amperes, kicked by the low power feed (7 ~ 9 VDC) from the key switch .
Easy and doesn't hack up the factory harness and isn't glaringly obvious .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline   Reply With Quote
Old 06-02-2023, 07:54 PM   #9
Jabes1
Jabes1's Avatar
Re: HEI Power & By-Pass Wiring...
The OEM coil will draw 50 amps? I like the idea of running it this way. I need to add a fusible link and I plan on connecting it to the accessory lug on the factory busbar. Do you run a fuse? How big of a fuse is needed?
Old 06-02-2023, 09:29 PM   #10
VWNate1
VWNate1's Avatar
Post Ignition Power Requirements
No ;
Either way draws under 15 amperes .
Ignition systems are typically not fused for safety reasons, I don't -ever- fuse them as I don't think I know more than the Engineers .
If it worries you, set up a separate dedicated power circuit and add a circuit breaker .
-Nate
Geezer
