Old 06-06-2023, 06:44 PM   #1
Ironhorse
Ironhorse's Avatar
Floor Mounted Gas Pedal
Not sure this is the correct pattern for our truck models, thinking it also swaps over to the Chevelle side of GM. Face and back with mounting holes are both in very nice condition. $10 plus shipping, money order, do not have Paypal.
Member RonWT has first call if interested.
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
Old 06-06-2023, 09:38 PM   #2
RonWT
Active Member
RonWT's Avatar
Re: Floor Mounted Gas Pedal
Hey, thank you for your offer, I am out of town till Friday, I will look when I get home if that works for you?
Much appreciated!!!
RonWT is offline   Reply With Quote
Old 06-07-2023, 06:24 AM   #3
Ironhorse
Ironhorse's Avatar
Ron, being a new board member first off I would like to WELCOME you to the best GM truck board you'll ever find on the web. Many like minded truck fans here who are very knowledgeable and readily share that knowledge when it comes to maintaining and restoring these trucks. Becoming a dues paying member was really a good decision on your part which will allow you to both buy and sell parts as needed.
Normal board policy altho not a hard and fast rule is a 24 hour period to allow a member to view a prospective part and use that 24 hour time slot to decide if the part is what they are looking for and will fit their needs. I have no problem for you waiting until Friday to make a decision on the gas pedal as to whether it will work for you or not. Just wanted to let you know some information as to how the parts buying and selling "normally" operates. Good luck in your truck project and again, WELCOME.
Wellington, Ks
Old 06-10-2023, 08:48 PM   #4
RonWT
Active Member
RonWT's Avatar
Thank you for offereing, I do believe it will fit, but I know the trim piece off mine will not work on that pedal. I appreciate it, but I will look around to try to find one that is matching to mine.
RonWT
Old 06-10-2023, 09:26 PM   #5
Ironhorse
Ironhorse's Avatar
RonWT, yeah, kinda figured the pattern would not be correct, just offering it up as a possibility for use until you find the correct pattern. Good luck in your search, the thrill of the hunt as they say.
Wellington, Ks
