01-08-2004, 12:43 PM | #1 |
ran out of money
pic's of auto xmember location?
Hello everyone I am in the process of rebuilding my engine and converting my 3 speed into a 700r4. I have already built the 700r4 and i am working on the engine now. The problem I have is I don't know were to put in the auto crossmember. I know i have to take the stick crossmember out and i think i know were the auto one goes, but there are a set of holes aready in my frame. do i use them? if someone has a picture of where there crossmember is located that would be great. Ohh yeah the engine is a 350 and in the stock location, and i will be putting in a 700r4 (but i think that it is the same location as a turbo 350)
thanks for everything
Modify everything, leave nothing alone!~ |
01-08-2004, 01:07 PM | #2 |
Yes, use the holes that are already there. Don't worry about which tranny you have, I'm pretty sure that all the automatics go in the same place.
01-08-2004, 01:28 PM | #3 |
My truck was a 4 speed 6cyl originally. Then it was a V8 with a turbo 350. Now it has a 700R and I had to drill new holes for the cross member.
1980 Chevy Shortbed Pickup 1969 Z28 engine Turbo 350 |
01-08-2004, 02:38 PM | #4 |
Why would you want Auto over Stick!!
Are you sure your OK? Good luck!
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
01-08-2004, 02:51 PM | #5 |
what I did was slide the xmember into the frame and push it back enough so I could jack the trans up and bolt it to the motor, then supported the trans with a jack so I could slide the xmember in place and loosely attach the rear trans mount so I could take measurements and make marks for where to drill the new holes...
Takes all the guess work out of it....
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA 72 Stepside Project |
01-08-2004, 06:16 PM | #6 |
ran out of money
What i am trying to do is have the crossmember in so i can bolt the engine and trans together and put them in as a whole. thats why i was looking for pictures, and maybe measurments. but i guess i am going to have to wait untill i have the engine done.
67chevemall-Yes i am fine, my 3 speed had major problems with it, went threw a clutch every 3 months and just didn't like being run hard. I felt as though the auto would give me more consistant times at the track, and with the 3 speed i had to lift the engine to get the clutch past the xmember (pain in the @$$). don't get me wrong i love sticks and my next project is going to be a stick, plus i drive an 89 blazer every day and that is lifted with an sm465. and thank you for the luck... i am going to need it with this truck Randy70c-10: do you have a pic of the holes to use. i guess the one of the owners before me put some extra holes in, so the crossmember can fit into 2 places, one more forward and one more rear. thanks for the help sorry to rable on everyone
01-08-2004, 06:25 PM | #7 | |
Resident Curmudgeon
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
01-08-2004, 07:13 PM | #8 |
yeah I'd wait until I could drop it all in and eyeball it on my own setup vs. using someone else's measurements.... it's a no brainer and you're guaranteed to do it right the first time.
01-08-2004, 08:02 PM | #9 |
A splendid one to behold
i swapped from a 3speed to a 350 auto also. i had to take the stock crossmember out, as you probably know the 3speed is a lot shorter than any auto. anyway, the new crossmember just bolted right up, the holes were already there. when i get home tonight, i will see if i can get a good pic for ya
67 swb 02 wrx |
01-08-2004, 08:19 PM | #10 |
700 rear trans mount is roughly 1.5 inches further back than a TH350, so the same frame holes won't work...
if I remember correctly, the 2 holes that would be for the rear of the xmember on a th350 application ended up being the 2 front ones for my 700, requiring me to drill new holes for the rear xmember bolts only.... so, for my setup at least, I could use the stock holes for the front of the xmember, and only had to drill for the rear xmember holes. This was for a smallblock mounted in the stock location on a short stepside truck originally equipped with a 6 cyl and muncie three speed column shift trans... Hope that made sense....????
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA 72 Stepside Project Last edited by bigvinnie; 01-08-2004 at 08:57 PM. |
01-08-2004, 08:37 PM | #11 |
Good info, that means now I have to go and move mine back.
01-08-2004, 08:46 PM | #12 |
yeah, ok...that makes since
67 swb 02 wrx |
01-09-2004, 12:16 PM | #13 |
ran out of money
thanks everyone for the help, looks like i will just have to grind the old cross member out and then when i put the engine and trans back in line up the auto crossmember and drill/bolt it in there........
thanks again for everyones help
