Old 06-12-2023, 08:48 PM   #1
jdl71
jdl71's Avatar
Boy is she rough…
…but they ain’t gettin any younger. My latest haul is a 65 C10 long fleet. Originally 525 Saddle and I believe a V8. I’d like to make this my last one, (lol) take my time and do it right from the ground up. I’ve started the easy part, taking it apart. We will see how it goes.
Psalm 23
64 C10
66 K20
jdl71 is offline   Reply With Quote
Old 06-12-2023, 09:38 PM   #2
Warrens69GMC
Warrens69GMC's Avatar
Re: Boy is she rough…
Well, it's all better from here. looking forward to progress.
1969 307, t350
1950 Chevy Wagon
1978 Big 10
1967 C10, 250,3-OTT
Old 06-15-2023, 09:09 AM   #3
bsarts
bsarts's Avatar
I'm glad you're saving it....
bsarts is offline   Reply With Quote
Old 06-16-2023, 11:10 AM   #4
Micmac
Micmac's Avatar
Keep us posted!
1963 Chevrolet C-10 "Ginger"
1970 C-30 Dump Truck "Scarlet"
2019 Chevy Silverado 2500 Z71 LTZ
1947 Indian Chief Roadmaster with Sidecar.
2012 Indian Chief Serial #002 of 110 built in '12
2016 Indian Chief Roadmaster
Micmac is offline   Reply With Quote
Old 07-31-2023, 09:27 PM   #5
jdl71
jdl71's Avatar
I’ve blown it apart and started on the cab. Had to patch both pillars and both kick panels. There wasn’t much left. This is an OER full floor from summit. It took me about an hour to get this installed by myself (the old floor had already been cut out).
I’m very pleased with it. The only issues are the two top holes not lining up with my kick panel patch and the rear holes on the right side do not line up. I believe both of these problems are 100% my fault. This truck was so rusty the old floor pretty much fell out of it and I did not have a lot of reference points to work from when I welded in my pillar ends and kick panels. Now that I have a fixed point to work from (the floor itself) I am able to measure and see what needs moved. I think I’m going to heat up the seam at the passenger side b pillar patch and see if I can persuade it to where it needs to be. Then I’m going to right side up the cab, put the doors back on, and set it back on the frame and see how it all looks. After that I’ll do the cab corners and then spot weld it to the back of the cab. Then I’m going to replace the entire firewall.
Psalm 23
64 C10
66 K20
Old 07-31-2023, 09:28 PM   #6
jdl71
jdl71's Avatar
Passenger side will need some tweaking.
Psalm 23
64 C10
66 K20
Old 07-31-2023, 09:30 PM   #7
jdl71
jdl71's Avatar
More
Psalm 23
64 C10
66 K20
Old 07-31-2023, 09:32 PM   #8
jdl71
jdl71's Avatar
It’s been a few years since I’ve been really active here, so forgive me for forgetting your username Norm, but I appreciate your comment on my fb post about how these cabs were built from the floor up. That’s sort of how I planned to do this and it was reassuring to hear that.
Psalm 23
64 C10
66 K20
Old 07-31-2023, 10:37 PM   #9
cwcarpenter98
cwcarpenter98's Avatar
Your progress is making me reconsider my path of rust repair. I was planning on just patching the inner rockers/floors, but that full floor pan sure does look like an easier option on paper. Please continue sharing your progress!
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 08-01-2023, 03:03 AM   #10
Braunschweiger
Great work, I like that very much.
Greetings Harald
My 62 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=829782
Braunschweiger is offline   Reply With Quote
Old 08-01-2023, 09:43 AM   #11
rbruno68
I am always amazed at some of the work guys are doing to save these trucks. I don't think I could do this type of significant repair. Looks great, and it is great you are saving another.
rbruno68 is offline   Reply With Quote
Old 08-02-2023, 11:55 AM   #12
raidmagic
raidmagic's Avatar
nice work
1965 C-10 1/2 ton shortbed part time daily driver
1980 C-10 1/2 ton shortbed project
raidmagic is offline   Reply With Quote
Old 08-02-2023, 12:41 PM   #13
MusicMan70
MusicMan70's Avatar
Subscribed for that complete floor work and thank you for posting it up.
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 08-05-2023, 07:18 PM   #14
factorystock
factorystock's Avatar
Originally Posted by jdl71 View Post
…but they ain’t gettin any younger. My latest haul is a 65 C10 long fleet. Originally 525.
525 is color code for Fawn in 1965.
factorystock is offline   Reply With Quote
Old 08-06-2023, 05:53 PM   #15
jdl71
jdl71's Avatar
I don’t know where I saw saddle, one of the paint charts may have had it wrong. Is that an exact match for the fawn interior? I had always heard that the interior fawn formula was not available.
Psalm 23
64 C10
66 K20
Old 08-06-2023, 06:02 PM   #16
jdl71
jdl71's Avatar
I hung the doors I have. They aren’t great and I’m not sure if I will use them but they fit “ok”. They fit just “ok” before considering how bad the cab was. I unbolted the right rear cab support to floor and renamed those holes out to get the b pillar to go back just a bit and it helped considerably. The hinges need pins and I didn’t spend a whole bunch of time adjusting them and they both open and close now without issue. I marked the hinges and I’m pretty confident the floor is where it should be in relation to the pillars and can move on to the rockers.
Psalm 23
64 C10
66 K20
Old 08-10-2023, 01:05 PM   #17
Grounded63
Those holes not lining up are probably 99% not your fault. That's just par for the course, with Import patch/replacment panels.
On my '63, I'm working on the drivers side. Inner/outer rockers lower A piller, front cab mount, ect. I've probably patched/welded up 75% of the holes. Then rescribed and drilled them once the panels were aligned properly. Import patch/replacement panels. Often just look similarly correct. But, generally still need to be tweaked. Or just plain finished, where they are missing correct details. To fit comparably to the factory panel they're replacing.
Looks great, with a full new floor in it !
Grounded63 is offline   Reply With Quote
Old 12-29-2023, 01:27 PM   #18
jdl71
jdl71's Avatar
more progess-door
Psalm 23
64 C10
66 K20
Old 12-29-2023, 01:29 PM   #19
jdl71
jdl71's Avatar
..door
Psalm 23
64 C10
66 K20
Old 12-29-2023, 01:33 PM   #20
jdl71
jdl71's Avatar
eyebrow...
Psalm 23
64 C10
66 K20
Old 12-29-2023, 01:35 PM   #21
jdl71
jdl71's Avatar
...eyebrow
Psalm 23
64 C10
66 K20
Old 12-29-2023, 01:38 PM   #22
jdl71
jdl71's Avatar
power wash, scrape and paint frame with redneck rotisserie. I used a propane torch and putty knife to get rid of the really solid gunk and it worked pretty well. Then just shot rustoleum through my gun thinned with acetone.
Psalm 23
64 C10
66 K20
Old 12-29-2023, 01:45 PM   #23
jdl71
jdl71's Avatar
I picked up a 250 from a 74 nova. Checked compression and it seems pretty healthy so i regasketed and gave it an aerosol overhaul and dropped in it. I also went through the sm318, cleaned, resealed and replaced some bearings but i dont think i got any pics of that. I also set the cab back on the frame as i need the room in the shop for winter.
Psalm 23
64 C10
66 K20
Old 12-29-2023, 01:50 PM   #24
jdl71
jdl71's Avatar
If i ever do this again i will do a couple things differently.
A) Try to leave the firewall/toeboard on and just fix it.
B) I pulled the roof skin off to clean under there and to fix the rust above the windshield and that was the right choice. The outer skin had a little rust around the edges and I should have just tried to fix that instead of having to source a new skin. Ive been using that for patch material so its not a total waste, but i really think it could have been saved.
C) If i had the budget I would just buy new doors. Ive got untold hours in just one and its still just "ok". Every truck Ive owned has always had a ding in the body line on the door and ive never been able to get that perfect.
Psalm 23
64 C10
66 K20
Old 12-29-2023, 02:49 PM   #25
theastronaut
theastronaut's Avatar
When you get to the rockers, make sure the inner lip that the door seal fits over isn't sticking too far outward. We've seen a few trucks with aftermarket rockers with that lip too far out and it makes the door really hard to close because the seal gets pinched. You may have to cut it off and weld it farther inward to align with the door correctly.
theastronaut is offline   Reply With Quote
