![]() Join Date: Mar 2015
Tilt shift indicator lamp.
I am attempting to solve my "too bright light" in my steering column shift indicator.
I have a factory tilt column with an aftermarket 4 speed shift indicator. I was wondering if the tilt column used the small steel bulb cover with the green cover? The other question is there seems to be a gap under the plastic cover that retains the L,R,N,4,3,2,1 lens. The radius don't seem to match exactly. I have been sticking a business card there so the light doesn't blind me at night. Anyone else having this issue? I am using an old USA manufactured bulb in the column. They are extremely difficult to get in and out because there is so little glass to grip. Cheers. |
#2 | |
The Older Generation
Re: Tilt shift indicator lamp.
If memory serves me correctly the stock bulb is a #53. Should be available at any auto store or maybe Wally- World.... LockDoc
Autometer makes green bulb covers for these #53 bulbs if your
column is missing this part (Autometer 3215 light cover on Amazon) Additionally, I have used green LED's for this with great success.
66 GMC Suburban Custom 66 Chevy K10 Suburban |
#4 | |
![]() Join Date: Sep 2014
Thanks for the bulb cover information. In need of one. ![]() I have replaced my dash lights with green LED’s and love the look and brightness of my instrument cluster now. Do you still use the metal cone and the Autometer bulb cover with a LED bulb? Would I achieve a bright green match for the PRNDL light? Any info about the LED part number/manufacturer would be great. Thanks Sam |
Howdy Sam:
That metal cone was designed to help focus the beam of light from the original style bulbs to the shift indicator area. My column just happened to still have this part so I run it with a green LED. If you are missing this cone and trying to track one down, try either ebay or https://gmtiltcolumns.com/steering-column-parts. Another option would be to reach out to user 70shortfleet, he builds quality columns and may have this part. For an LED source I use www.superbrightleds.com. The #53 use BA7 type bases, so you can look them up this way. Hope this info is helpful but happy to help where I can if you have other questions, feel free to PM me. Thanks,
Thanks for the reply Southcity.
I do have the original metal cone. I also have the cone cover but it is bleached out from 50 years of use. ![]() I appreciate the links and bulb info. Thanks again. ![]() |
Good info, my green cap came off trying to remove metal cone. Metal cone should come off without dismantling whole column? Any tools effective in removal.
http://67-72chevytrucks.com/vboard/s...d.php?t=635605 |
No need to disassemble the column.
The metal cone should just slide out. Small metal pick should help. Once you get it out you will see its cut out slot for alignment to reinstall. Hope this helps. ![]() Last edited by samkost; 06-21-2023 at 02:21 PM. |
I did change the bulb to a green LED like others recommended.
I still am not sure if the metal shield was included in both tilt and non=tilt columns? I still have the light leaking issue. I plan on trying the metal cover on the led? Possibly it will work at cutting the glare on the dash? One can see the gap at the lower part of the indicator. It allows light to shine directly into my eyes and I also have the reflection from the dash. Not ideal. Just one of the many smaller details I am attending to. Cheers |
I used a green led that is flat and points upward with no metal housing as it wouldn't fit over the led bulb. I also used 2 thin pieces of foam and 2 way tied them to the flat part of the lens under the housing. It worked wonders for light bleed and no visual of them once installed.
#11 | ||
Always on the hunt...
![]() Join Date: Sep 2006
![]() Also: For anyone interested or looking, we do have a long discontinued tilt specific GM NOS turn signal switch with the extra bulb socket & power wire harness available in the below linked parts board F/S thread, the t/s switch is listed as item #16 on the NOS parts list. http://67-72chevytrucks.com/vboard/s...d.php?t=798288 .
***For any return/past customers & friends*** Before sending of any funds, please wait for a confirmed total and instructions for sending as our payment account info has been changed as of Jan. 2023. Thanks... |
More pics...
#13 |
Last of the pics...
#14 |
Slightly off topic. Over the years I have picked up half a dozen or so of these green & amber caps at swap meets and what not. Anyone know the application of the amber caps?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
#15 | |
That is exactly what I am trying to achieve to match the dash gauges! ![]() ![]() ![]() Sam |
#16 |
Eulogio, here are the two OE used tilt column shift indicator dial lamp cap/filter setups and the OE used shift indicator dial lamp socket, 1445 bulb and power wire harness that are packaged up and headed your way. Prior to shipment, we went ahead and powered up and tested the lamp socket and harness setup as seen in the below pictures. Thanks again for your order and let us know if you end up needing a brake booster to firewall mounting bracket setup (we took some pics). Mel
#17 |
Richard and bowtie72, here are pics of the OE used tilt column shift indicator dial lamp cap/filter setups that we can get shipped off to you both, the total and payment info for sending of funds via paypal has been forwarded on Sat. 08/12, please confirm your full shipping address's and we'll get the parts ready for shipment. Thanks, Mel
#18 |
Accelo- Did you make that shift indicator with the OD on it? I just put a 4l80e in my truck- and would love to have the indicator match up!
Thanks, Steve
'71 Chevy 3/4 Ton Longbed '22 Chevy Tahoe RST '67 Firebird- 8 sec street car '24 GMC CC 4x4 Duramax Dually |
#19 |
Hi Steve, I got an OD shift indicator from Les (70shortfleet) when I switched out to a 700R4 a couple of years ago. I originally got the column from him, but was running a TH350 at the time.
1967 C20, 350 SBC w/Comp roller cam, 700R4 w/3.42 posi, PS, 4-wheel PDB, Old Air AC & GM Tilt column. |
#20 | |
![]() http://67-72chevytrucks.com/vboard/s...58#post9229958 .
#21 |
Active Member
![]() Join Date: Jun 2018
Turns out I have an amber one. Wish it was green, as I find it to be too bright to match the rest of the instruments at night.
1971 Pontiac Firebird 1971 GMC C2500 |
