06-20-2023, 11:33 AM | #1 |
Stock Battery Hold down - Only one bolted on clip holds the battery?
Thinking about ordering a stock battery hold down set up. Is it really only one bolt down clip that holds it down or is there one on the other side between the battery and rad support?
1971 Chev C10 - 250ci L6 w/3 speed on the floor Upgrades: Power Steering 3 Core Radiator 7 Hole Gauge Cluster Power Brakes (Incoming!!..) 1971 350 (Incoming!!..) |
06-20-2023, 12:04 PM | #2 |
Re: Stock Battery Hold down - Only one bolted on clip holds the battery?
Just the one bolt, issue is--- most of the time the clamp gets installed upside down
06-20-2023, 12:19 PM | #3 |
Yep. Just the one bolt and clamp. My 72 C10 been that way since day one.
06-20-2023, 12:41 PM | #4 |
It is a bit comical isn't it? I had a Malibu with the exact same battery position and clamp as these trucks. One time under hard acceleration the battery actually popped out of the clamp and was bouncing around the engine compartment, tethered only by the battery cables! I added a strap over the top after that. On my truck, I completely ditched the stock mount/bracket and relocated my battery. This one should never jump out of the bracket!
Builds: Green Gus the 68 C10 ; Sullii the 72 1500 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
06-20-2023, 12:59 PM | #5 |
There's also a lip at the back bottom of the tray that's supposed to hold the battery as well.
72 C10 lwb fleetside -stock 350/350 combo |
06-20-2023, 01:01 PM | #6 |
All 3 of my Chevys, 67, 72 and 96 all have the same 1 bolt hold down using a 78 series battery. Never had any problem "throwing" a battery out of the tray...although I don't do any Dukes of Hazard jumps of off road driving.
The 96 I drag race for years and part of tech inspection is the guy grabs battery to confirm it has a hold down. Like either top or side post (78 series) battery's there is a lip just like the post above never start battery for the 1 bolt clamp to hold on. |
06-20-2023, 03:07 PM | #7 |
And that setup has always worked just fine for me on several different cars and trucks. It's hard to see how a battery could come loose, because the rear hold-down bracket forces it forward under the battery box's front lip. But your battery also has to have that corresponding lip. That may not be the case with all batteries.
Mike 1969 C10 LWB -- owned for 34 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 23 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
06-20-2023, 05:09 PM | #8 | |
Location: Herculaneum MO (20 minutes south of St. Louis
67 C10 283 T5 swapped longbed fleetside = wife's daily driver 67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck 67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD 72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck Can you tell we are fans of longbed fleetsides & 67s Chris Last edited by 67 twins; 06-20-2023 at 05:14 PM. |
06-20-2023, 05:31 PM | #9 |
There's a ''lip'' on the Battery Carrier's front that's supposed to engage a raised ridge on the base of the battery, and is then clamped down by the piece in back. I replaced the Carrier on my '68 Stepside with a new one after corrosion killed the old one. With the new carrier the system works. But I have used big zipties, [2 and-a-half footers] to secure the battery in the past.
Once. after getting out to a western set from another remote location, I was horrified to find the battery had fallen back from all the 4-wheeling in my '71 GMC Jimmy. Battery acid had leaked out and burned the paint on the outside of the passenger side fender before I caught it. The next step was to find a battery plate from another junkyard vehicle that had front-and-back circular mounts for hold-down hooks, and get it welded onto the triangular GM carrier brackets. So now my 4x4 Jimmy has a pre'66-style batrery hold down. On the long cable ties, they can be re-used if you can release them by getting a pen knife blade or O-Ring pick under the ratchet tab and lifting it up over the grooves. Cheap fail-safe and saves your fender paint.
