Proper Fuel Sending Unit ?
Trying to locate the right unit for a 71 307 2 barrel carb ? Confused about oms range and line size ?
71 C-20 07 Magnum RT AWD |
Re: Proper Fuel Sending Unit ?
307 had 5/16", or my 1969 does.
https://www.ebay.com/itm/35399746723...3ABFBM9Nmx_6Ji replace brass float https://www.ebay.com/itm/17396266899...Bk9SR_Djt_-iYg |
![]() Join Date: Jun 2022
https://faq.speedhut.com/kb/fuel-lev...tance-o-ranges
You should be able to check your existing sender with a multimeter to confirm |
![]() Join Date: Sep 2007
Supposed to be 90 ohm right?
1967custom |
All GM vehicles of this era use 90 ohm fuel sending units, configured to fit a specific vehicle.. Tubing size is referenced by its outer diameter.. Use this tool for taking that measurement. Can also be used for measuring lots of other stuff.. https://www.harborfreight.com/6-in-d...65fdb65f738212
90 Ohm & 5/16" line. I'm not 100% on this but I think in trucks of this era the 3/8" line was for used for big blocks only.
Thanks guys for the information ! I will get one of those and measure the pipe to be certain.
