Old 07-04-2023, 07:11 PM   #1
zac
zac's Avatar
‘79 K20 Camper Special U-joints
Replacing my rear driveshaft with a better one with no slip yoke wear, swapping the u joints first. I always have trouble looking up parts for this truck because of the weird combination of parts. 10 bolt front, NP203/TH400 with a 14FF rear axle. The Rockauto Autozone, whatever references are almost always wrong. I pulled the old ones off, likely the originals. The transfer case end says Spicer P621. I believe the new Spicer # is 5-760X. Its not greasable, I wouldn’t mind having one that is. The axle end u joint is larger, caps 1-3/8” approximately. One side says “Spicer Can” with numbers F3-5-69 and a big X in the middle. The other side says A525. None of these numbers are helpful when trying to look it up. I’m hoping the 14FF used a standard u joint and somebody here knows the part number.
zac is offline   Reply With Quote
Old 07-04-2023, 10:18 PM   #2
cadillac_al
Re: ‘79 K20 Camper Special U-joints
It most likely has 1310 U-joints with a 1350 at the rear axle.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 07-05-2023, 12:31 AM   #3
farmall
farmall's Avatar
Take your cup dia. and overall width to the chart.
https://neapcoaftermarket.com/wp-con...og-9901018.pdf
G numbers are non greasable.
1955 GMC 250 8 Flatbed
1971 C30 157" 350 4spd 10' Flatbed
81 GMC K30 CnC 9' Flatbed 454 T400
89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958
71 LT1 Convertible, 72 Coupe
69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2
farmall is offline   Reply With Quote
Old 07-05-2023, 10:59 AM   #4
zac
zac's Avatar
That’s a great chart, and Al guessed right. Thanks both for your help.
Old 07-06-2023, 01:25 AM   #5
kwmech
Should have 5-760x on the rear shaft 1350 series (both joints)
Old 07-06-2023, 08:03 AM   #6
cadillac_al
I actually moved my slip yoke to behind the transfer case and used a conversion U joint at the rear axle. Now the slip yoke has a much calmer life than it did bouncing around and twisting with the rear axle.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
