07-05-2023, 10:59 AM | #1 |
69 vs. 70-72 fuel tanks
I'd like to replace the 54 year-old fuel tank in my 69 C10. But I want to use a tank with EEC to get rid of the gasoline smell in my garage.
Vendor pictures show the 70-72 tanks as having a tube close to the filler neck, but the the sending unit also has a tube next to the fuel line tube. Where are these connected to? Does one go a charcoal canister, and the other to a mechanical fuel pump with a return port? And did the factory run rubber lines all the way to the engine compartment? Oh, and will a 70-72 tank bolt in exactly like my 69 tank? Thanks.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
07-05-2023, 11:23 AM | #2 |
Re: 69 vs. 70-72 fuel tanks
This thread has the info you require. http://67-72chevytrucks.com/vboard/s...d.php?t=845195
07-05-2023, 11:32 AM | #3 | |
No, rubber lines only connect the hard lines. Yep, the new style tank would bolt in but you would also need all the EEC lines. Both in cab and along the frame to the engine compartment. I used a Spectra brand tank from Rock Auto. Bolted right in and only need a very slight tweek/adjustment to the filler neck to center it in the body. Very easy to do using a large pipe or floor jack handle. Tank https://www.rockauto.com/en/moreinfo...pt=6268&jsn=11 Sender 32-4024 (72 manual) https://www.lmctruck.com/1967-72-che...and-components Last edited by jnewt; 07-05-2023 at 12:15 PM. |
07-05-2023, 12:24 PM | #4 |
My truck sender tube is 3/8" so I should be OK there, unless there's something different between mine and 70-72. The rest of the fuel line is 5/16" because the truck's original engine was a 307. I've never had a fuel starvation problem that I know of, but have been meaning to convert to 100% 3/8" line.
I don't plan to run a return line, so should be OK there. Looks like my major task will be running the EEC line. But I don't understand this pipe and hose routing (from the other thread) at all. No charcoal filter? Bizarre. Maybe I'll just forget about it. I read an article awhile back about how the gas smell in the garage may be fuel evaporating from the carb, and a way to cure the problem. Makes sense because I mainly notice the smell after a drive. Have to see if I can find the article.
07-05-2023, 12:30 PM | #5 |
Ya those EEC lines inside the cab just make a loop up inside the passenger side of the cab (guessing to prevent fuel from entering them). That line then runs through the floor of the cab along with the fuel supply line from the sender. The lines parallel each other along the frame to just past/forward of the fuel pump. Rubber line then hooks the hard EEC line to the evap canister which is mounted kinda below/between the battery and fender
07-05-2023, 12:39 PM | #6 |
Thanks, man. Makes sense now.
07-05-2023, 01:34 PM | #7 |
Who Changed This?
Might be a lot less work to install an exhaust fan in the garage and put it on a timer. Adjust the timer to turn off when the stink is gone.
07-05-2023, 02:08 PM | #8 | |
Even after acquiring and running all the lines, you will still need to acquire then rebuild a EEC canister. Which is a whole task itself. The canisters are sealed and not meant to be rebuilt. |
07-05-2023, 04:06 PM | #9 | |
I think I can still buy a new one, but I'd need to find a place to mount it and make a bracket. Not too complex.
