RUNN over AGAIN!!!
can i somehow rearange some of those bars??
Has anyone made a 4-link???? i would really like to know. ,Ryan
67-72 TRUCKS ROCK 70 SWB shaved and a 72 front clip.and a poly tank. Peep mirrors and a BIG BLOCK 468 in the making. XNXNXNXNXNXNXNXNXNXNX ,/. EMAIL ME HERE!, Dont pm me please ,/. |
What is your current set-up?
RUNN over AGAIN!!!
SCOTI,
STOCK!!! and NOT leafs its I believe a 2-link setup?? is that right?
Is there a particular reason you want to use a 4-link suspension?
The factory 2-link trailing arm arrangement on 60's-72's works quite well. The biggest improvement can be made by just getting a lower COG (center of gravity). Air bags are easily adapted & not only ride well, they can be adjusted so you can use your truck as a truck (not that you couldn't do the same w/a 4-link).
![]() Join Date: Aug 2003
trailing arms rule. if you look on the air ride tech website, the airbag setup for the back is about $429. they sell 4 link kits as well.
Trucker.
I agree with Scoti just work with the trailing arms and put in a notch and the rear bag kit bigbluthng suggested and you'll be golden.
Ya, what we have on our trucks is the setup they use in NASCAR
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html " TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410 </A> |
Trailing arms are definately the way to go! My friend had a 68 bagged without shocks in the back and it still rode awesome!
I want my truck done! |
