07-11-2023, 12:37 PM | #1 |
AC Compressor hoses connector bolt
I'm reconstructing the missing AC system for the 83. I got my parts on order but one thing I'm missing is the bolt that connects the dryer and evap lines to the back of the compressor.
Being as there aren't any square body trucks in the parts yards here locally, anyone replaced/disconnected/re-connected these lines recently that can tell me if it's a special bolt or one I can pick up at Home Depot? Thank you |
07-11-2023, 08:42 PM | #2 |
Re: AC Compressor hoses connector bolt
Nothing special, but there is a chance it may be metric
07-13-2023, 05:57 PM | #3 |
As luck would have it, the new compressor came with one.
Thanks for your reply just the same. |
07-13-2023, 09:27 PM | #4 |
Great news
So for the Forum (thread) research. Was the bolt metric ? How long was it? This will add info to the forum And this will help the next Gearhead
________________________________________________________________________________________ ____________________________________________ 84 Chevy K-20 63 Impala (my high school car) http://67-72chevytrucks.com/vboard/s...Crew Cab Build |
07-14-2023, 07:16 PM | #5 |
You can see it has 8.8 cast into the head. It takes a 5/8" socket to loosen/tighten it so.... I dunno. I was going to remove it to get some measurements, but it is under pressure (prefilled with some oil) and I didn't want to risk moisture contamination today. It may be a couple weeks before I get to installing it. I'll update when I do.
07-14-2023, 10:00 PM | #6 |
In the 80's they made some bolts with metric threads and a Standard wrench size hex.
They done this because of the production line process. And also the vendors that parts came from played a role in this. I just found this to be true on my 208-transfer case I am working on. In the reverse order /metric head with standard threads. Metric socket and 3/8-16 TPI threads. Working at a Automotive plant for years I learned a lot about this. They have to set up each job station in the assembly line So the technician works efficiently. So in the 80's the engine components were standard and under hood stuff was metric. The technician would use one air gun too shoot 20 bolts in a minutes time.
07-14-2023, 10:08 PM | #7 |
Just did one on my 73 GMC. Replaced factory A6 compressor with a Pro6Ten. Your bolt is only long enough to hold the seal plate on and you will have to add for the line block. The AC bolt I just bought for mine was a 10mm x 1.50mm x 45mm long. That's using a washer head metric bolt if you are using a no flange metric bolt take into consideration for a washer or lock washer thickness. I use my digital caliper to measure the thread hole depth and round it down to the next shorter bolt length(generally 5mm increments) to get maximum threads in that aluminum bore. Also note all your mounting bolts will be metric also in case your original need updated.
'66 CST BBW swb fleet 327 fac ac '67 CST 4x4 swb 327 stepside project '72 Cheyenne K20 50k original '72 Cheyenne Super K20 project '73 Sierra swb 4x4 frame off in paint stage '74 Cheyenne Super swb w/16k actual '71 & 72 Cheyenne K10 4x4 swb's '70 426 HEMICUDA conv SHAKER 4 sp Dana 60 '60 Impala conv 327 PG fac ac loaded 3rd owner '72 GMC K2500 4x4 '59 Apache CST BBW fleetside swb 283 '73 ElCamino SS LS1 T56 true SS bucket tach '76 ElCamino SS 52k survivor '87 Grand National 41k True 2nd to last built in 1987. '86 K30 454 SRW fleetside CA since new '88 Trans Am GTA 39k bought new 2018 DEMON plum crazy @ 840HP! "Need for speed" |
07-15-2023, 08:15 AM | #8 |
Great info. Thank you!
